General Automotive Discussion
View Poll Results: best torque engine
FORD 390
13
27.08%
FORD 351
8.33%
FORD 460
29
60.42%
FORD 302
4.17%
Voters: 48. You may not vote on this poll
torque
Old Sep 9, 2004 | 11:03 AM
nick88f150's Avatar
nick88f150
wow...that is a massive engine. i know its real but it looks like something someone would photo shop, the pistons were like the size of some cars
Old Sep 9, 2004 | 11:14 AM
77fordguy's Avatar
77fordguy
gotta go with a 460 on this one.
how much torque did the old motor's actually make at he tires compared to today's cars? I know the 460 in 70 was rated around 300hp and 500ft.lbs. but what did a lincoln that had this motor actually dyno at?
Old Sep 9, 2004 | 12:49 PM
F2504x4's Avatar
F2504x4
Originally Posted by pfogle
The 302, is a good motor for a car, but when you really want to pull or haul something you need a bigger engine.
the 5.0 in my last truck was a good solid work horse, 95 F150 4x4 extracab 8ft bed with the e4od w/370,000 miles onit no mods, would pull 7000lbs with no problem, and yes it did work the engine hard, but it did do the job, and i was not easy on the truck.
p.s. i bought this truck with 40k on it and went through two engines , each lasting 150,000 miles but i never touched the trans . the 302/5.0 is one tough engine........
i also had a 91 GT ragtop 5sp that would flat out git it.....
Old Sep 9, 2004 | 01:52 PM
FORD352V8's Avatar
FORD352V8
The 400 sucks, toruq first. The FE's are unbeatable and can be built to have tons of torqe. My modded 352 puts out 400ftlbs. Thats more then plenty and it is a mild build. I towed a 10,000 pound tralier with it up some steep grades and it was overlaode big time but the 352 pulled fine. I even passed a few people going up. It still had more then enough power even when it was overloaded. It is one hell of a towing truck now.
Old Sep 9, 2004 | 01:59 PM
equium's Avatar
equium
Originally Posted by bigrigfixer
I never got to drive a 390, so I picked 460. Gobs and gobs of torque that old truck of mine had.
And the old motorhome we had (90 Econoline, 27' Glendale Sterling) had the 460 as well. No problems passing uphill either.
SWEET! i'm buying a 1990 29' Class A RV with a E350 front clip and a 460.
Glad to hear i'll have plenty of power and torque. (only 46K miles on the motor BTW)
Old Sep 9, 2004 | 07:25 PM
ga302p's Avatar
ga302p
The 302 shouldn't even be in this poll. Replace it with 427, 428, or 429.
Old Sep 9, 2004 | 07:27 PM
ga302p's Avatar
ga302p
Originally Posted by ford390gashog
why doesn't ford make any v-8 engines that make alot of torque like the ones they used to build like the fe's
Sadly, Ford has recently become scared of Cubic Inches.
Old Sep 9, 2004 | 07:51 PM
frenchi's Avatar
frenchi
2nd Gear
My father used to have a 76 f-250 4x4 whit a 428fe 36"tire and 4.10 rear end it made gobs and gobs of torque
Old Sep 9, 2004 | 09:08 PM
snowfighter's Avatar
snowfighter
I put my 400 up against anything listed.
Old Sep 9, 2004 | 11:16 PM
MustangGT221's Avatar
MustangGT221
I'd agree that the 300 puts out high low end torque (260 at 2k rpm)... but the 302 puts out more torque than a 300, but at 3000 rpm not 2000. Neither are particularly high (260-270 isn't much), so I feel neither are wonderful.
Old Sep 10, 2004 | 09:00 AM
basstardo's Avatar
basstardo
I'd be glad to take the Pepsi challenge on that...
Old Sep 10, 2004 | 09:53 AM
77fordguy's Avatar
77fordguy
but they are making the same power with better drivability and better gas mileage.
Old Sep 10, 2004 | 11:42 AM
  #28
snowfighter
That PSD wasnt listed I might be a little crazy but not stupid!
Old Sep 10, 2004 | 12:04 PM
  #29
basstardo's Avatar
basstardo
LOL...I thought you mean listed in the threads above. You could probably take my truck if you had the gears to do it and the motor was built out enough. 3.73 with 35's is kinda rough. I've seen a Jeep ****** out pull a built up 460 purely on gears. The 460 was 2WD though...
Old Sep 10, 2004 | 01:02 PM
  #30
Saurian's Avatar
Saurian
302 - 185 HP @3800 rpm's, 270 Tq @2400 rpm's
300 - 150 HP @3400 rpm's, 260 Tq @2000 rpm's
The 302 has to go 400 rpm's further to get MORE torque and horsepower? I know the 302's torque curve isn't as flat as the 300's, but I refuse to believe that it is that far behind the 300. I have read this over and over, but I didn't realize the torque peak was that close. And the 302 can at least live above 3000rpm's. I used to be a 300-is-better guy, but since I've actually taken the time to read up on the 302 - it's not that bad. It isn't quite the grunter that the 300 is, but its not a weakling either.
