1969 360 problem
Old Sep 8, 2004 | 10:37 AM
chromiumh1's Avatar
chromiumh1
1969 360 problem
I rebuilt a 1969 ford 360 in college several years ago and since then the oil pressure is very low (10-15lbs). I have tried changing the oil pump, that did nothing. I have a hunch that it could have something to do with the cam bearings. Im not quite sure if they had to go in a certain way, but if they did i may have put them in wrong and now the oil could be coming out the timing cover causing the loss in pressure. What can i do to find out for sure what the problem is?
Old Sep 8, 2004 | 10:55 AM
Old Blue 2's Avatar
Old Blue 2
Could you tell me a little more is that hot idle or a cold idle or running at rpm pressure
Old Sep 8, 2004 | 10:58 AM
chromiumh1's Avatar
chromiumh1
Its at cold idle.
Old Sep 8, 2004 | 11:03 AM
Old Blue 2's Avatar
Old Blue 2
Thats low when you first start does it go higher or up when you increase rpm or does it just stay I know I allways use restrickters to the top end for hot idle pressure. Let me know I can most likley help.
Old Sep 8, 2004 | 11:04 AM
chromiumh1's Avatar
chromiumh1
It stayed low even when rpm's were up, didnt get any higher when engine heated up.
Old Sep 8, 2004 | 11:23 AM
debestuss's Avatar
debestuss
You rebuilt the engine several years ago. Has the oil pressure been low the whole time or has it just recently started dropping off?
Old Sep 8, 2004 | 11:27 AM
chromiumh1's Avatar
chromiumh1
was low off the bat. Has only ran for a couple of hours.
Old Sep 8, 2004 | 12:22 PM
Old Blue 2's Avatar
Old Blue 2
Hey sorry about the slow responce just got back from a trip and the dog needed to play. Anyways sounds like you forgot to put the galley plugs in .Tthe cam bearings would have pressure but starve the mains you might be able to see the plugs by removing a valve cover I"ll go out and check the motor I have a part and tell what side is best . Sorry but looks like the intake comes off but the plugs are on top of the valley.
Old Sep 8, 2004 | 12:33 PM
chromiumh1's Avatar
chromiumh1
Almost possitive that all of the galley plugs are in,but i could be wrong. How many of them are there?
Old Sep 8, 2004 | 12:37 PM
debestuss's Avatar
debestuss
When you put the motor back together, do you remember if you put the oil galley plug back in the front of the motor behind the timing cover where the camshaft is? There's also one behind the distributor shaft, behind the timing cover--if you are looking at the engine, there should be a hole that you can see the distributor shaft--behind the shaft, on the inside, there should be a plug.
When I put mine back together, I forgot the plug for the camshaft and ran extremely low oil pressure.
Old Sep 8, 2004 | 12:49 PM
chromiumh1's Avatar
chromiumh1
Do i just have to take the timing cover off for that? No i dont remember
Old Sep 8, 2004 | 12:52 PM
Old Blue 2's Avatar
Old Blue 2
I can't remember how many let me do some checking and get back to you
Old Sep 8, 2004 | 12:53 PM
debestuss's Avatar
debestuss
No, just the timing cover.
Old Sep 8, 2004 | 12:54 PM
chromiumh1's Avatar
chromiumh1
cool i will look at it tonight, thanx I will let you know if that was it.
Old Sep 9, 2004 | 11:30 PM
Larry_the_handyman's Avatar
Larry_the_handyman
Wink Thinking outside the box
I don't wanna sound like a wise-a$$, but have you checked the gauge? Maybe you have oil pressure and the gauge just isn't reading properly. It's way easier to check that than pulling the engine apart. I've been burned by the simple things myself, so I'm just trying to save you from banging your head against the wall.
Larry
