1969 360 problem
Old Sep 9, 2004 | 11:51 PM
Jsbiohazard's Avatar
Jsbiohazard
Did you line up the holes on the bottom of the bearings with the holes in the block? Also, the bearings get progressively smaller towards the back of the engine, did you put them in order?
Old Sep 10, 2004 | 10:51 AM
chromiumh1's Avatar
chromiumh1
Originally Posted by Larry_the_handyman
I don't wanna sound like a wise-a$$, but have you checked the gauge? Maybe you have oil pressure and the gauge just isn't reading properly. It's way easier to check that than pulling the engine apart. I've been burned by the simple things myself, so I'm just trying to save you from banging your head against the wall.
Larry
Yes i tried another guage on it was still only 15 lbs
Old Sep 10, 2004 | 10:52 AM
chromiumh1's Avatar
chromiumh1
Yes everything there went back in the way it was supposed to
Old Sep 10, 2004 | 10:57 AM
debestuss's Avatar
debestuss
Originally Posted by chromiumh1
cool i will look at it tonight, thanx I will let you know if that was it.
Have you pulled the timing cover off yet?
Old Sep 10, 2004 | 11:10 AM
chromiumh1's Avatar
chromiumh1
i was going to got to busy to do it yet gonna do it this weekend for sure
Old Sep 10, 2004 | 11:21 AM
debestuss's Avatar
debestuss
You put the bearings in right and the oil gauge is working properly. You've changed the oil pump. You've pulled the valve covers to see if you're getting oil on top. I'll bet you didn't put the oil galley plug in behind the timing cover. Are you using a copper line from your oil filter adapter? One more thing you could try is using a short piece of copper to check the oil pressure. I used a 8" piece of line with a gauge on it. Maybe your tubing has an obstruction. It's a long shot.
Old Sep 10, 2004 | 11:47 AM
chromiumh1's Avatar
chromiumh1
cool thanx for the input im getting more excited to get to the bottomof this mystery. thanx again for everyones help
Old Sep 13, 2004 | 07:21 AM
chromiumh1's Avatar
chromiumh1
Where exactly is the oil galley hole behind the timing cover, there were the three hole above the cam none of them appeared to be a spot for one. And i think i actually have a 352 because it is stamped on the block. Is that going to make any difference with anything? thanx
Old Sep 13, 2004 | 09:07 AM
debestuss's Avatar
debestuss
All the FE's have 352 stamped on the block, don't worry about that. If you are looking at the front of the motor you should see three holes sure enough. The one on the far right should reveal the distributor shaft, inside the motor BEHIND the dizzy shaft is a hole that should be plugged. Now we have two more holes on the outside. The one at about 11 or 12 o'clock should be plugged, it'll be the middle hole. The one to the left should be open. Hope this helps.
Old Sep 13, 2004 | 09:40 AM
chromiumh1's Avatar
chromiumh1
Thanx ill take a look at it.
Old Sep 13, 2004 | 10:05 AM
chromiumh1's Avatar
chromiumh1
Dont the galley plugs thread in. The hole is open and i put a 7 inch long screwdrive in it, never hit anything. But i dont feel any threads in it. Sorry for making this such a drug out thread, i dont know a whole lot about this stuff. But this site is an extreme help. Hoping that that is the problem. Thanx for your help once again.
Old Sep 13, 2004 | 10:08 AM
debestuss's Avatar
debestuss
My galley plugs were 1/2 tap in's. You won't hit anything, it's a tunnel that fills with oil.
Old Sep 13, 2004 | 10:39 AM
  #28
chromiumh1's Avatar
chromiumh1
Do they thread in right in the front? What I meant was i couldnt feel a plug with the screwdriver. I didnt see any threads in the hole. If they thread in how deep is it? Hopefully i can be done with this soon so i can get onto a different subject. Thanx for being patient with me.
Old Sep 13, 2004 | 10:44 AM
  #29
debestuss's Avatar
debestuss
If you are putting a screwdriver in the hole, then it doesn't have a plug in it. The top hole on the front of the engine should be plugged, threaded or not. You would be able to see it with no problem. If it's not threaded, don't worry about threading it until you rebuild you motor again. Any machine shop should have some freeze plug type oil plugs you could get for next to nothing.
As far as patience, don't worry about it. I've bugged the crap out of these guys with similar issues.
Old Sep 13, 2004 | 10:50 AM
  #30
chromiumh1's Avatar
chromiumh1
Ok cool that should solve my problem then. That would explain why i didnt have any extra parts when i was done. I probably ruined it taking it out and threw it away, and didnt remember to get a new one. Thanx for the help i will be on here on a regular basis now. You guys have the answers that a lot of people dont. Thanx again.
