Do I still have time?
Old Sep 8, 2004 | 02:55 AM
big hoss 29's Avatar
big hoss 29
I have an 86 F-250 with the 460 in it. I moved to a place where I don't have any emissions tests. I want to put on an Edelbrock intake, Edelbrock carb, and Mallory distributor. I also want to put on Hedman headers and true dual exhaust. My problem is that this truck is going through about 1 to 2 quarts of oil a week, depending on how far I have to drive. I haven't done a compression test, but I suspect that the rings are going out because when I stand on it, I can see blue smoke coming out of the exhuast. This engine is strong with no ticking or any other problems. I'm just on the fence as to whether I should find an engine and rebuild and wait for the old one to croak, or should I go ahead and buy the parts I want and swap them when the time comes to the new engine? Do I still have time to enjoy these parts?
Old Sep 8, 2004 | 03:51 AM
locknkey's Avatar
locknkey
The more you stand on it, the worst it will get, if you decide to put all that stuff on it, it will go puff in no time, if I was you, instead of doin the modifications to an already weak motor (bad /broken compression rings will just make it burn that much oil quicker than it is already... ) it would be MUCH better to redo the engine the right way, than to throw it all away and waste it on a weak and perhaps an already high mileage engine.....your choice.
Old Sep 8, 2004 | 10:47 AM
Oaktree's Avatar
Oaktree
If you were to rebuild your existing motor and put in a bit more cam amd possibly up the compression a bit you might be suprised at how much that will help.I would also think about starting with the exhust mods first,if you can't get a motor to exhake,no use trying to make it inhale better.just my 2 cents.
Old Sep 8, 2004 | 11:33 PM
mustange70's Avatar
mustange70
If you are on a budget for a rebuild just put new rings, gaskets, bearings, flat top pistons, a new rv cam set with lifters, if you do it yourself you can do a rebuild for about a $1000 but that is minus those mods you want to do, with the mods you can safely add another $1000-$1500 easliy.
Old Sep 10, 2004 | 02:19 PM
82F1507.5's Avatar
82F1507.5
7.5l
My F-150 came from the factory with a 351W but now sports a Ford crate 535 HP 7.5L 460. Yes, I used the motor mounts and accessory brackets from an 83 F250 7.5L.
The crate motor cost $5500 delivered to my local Ford racing dealer. I could not build the same engine for much less plus considering the cost of the Cobrajet aluminum heads which came with the crate motor.
I agree with the others. Don't put new parts on a tired engine. Rebuild or buy rebuilt. You are way ahead of the game.
Ummm...don't plan on standing on the crate motor for very long unless you happen to be at a drag strip, it will hurt you
Old Sep 10, 2004 | 03:21 PM
big hoss 29
Well, I guess what I meant by stand on it is when I pass someone or get on the highway on-ramp. I know that this truck isn't a race vehicle by any stretch of the imagination, but it is nice to have a 460 to motivate me along. I should also say that it seems to burn more oil when I use Valvoline rather than cheap convenience store type oil. That's why I was hoping that I would still have time as the engine is strong other than that.
Old Sep 10, 2004 | 03:52 PM
locknkey's Avatar
locknkey
Have you check the plugs to see if they are misfiring or is blacked with oil? When you remove the ( any) sparkplug, is there oil on the end, or is there so much leakage from the valve covers that its leaking around the plugs? You can do a compression check if you get a compression checker...usually if the cylinders are within 10% of each other, the cylinder has good compression...if other than that, its questionable if its rings, oil rings..or cylinder wear.
Old Sep 10, 2004 | 04:14 PM
82F100SWB's Avatar
82F100SWB
If it's blowing blue, it isn't a strong engine, PERIOD. With that amount of oil useage, I wouldn't think about putting any performance parts in it.
1-2 quarts a week is BAD. The one I just replaced in my 86 used maybe a quart every 5000 miles...
Old Sep 10, 2004 | 05:27 PM
locknkey's Avatar
locknkey
I agree....save up and get a new or rebuilt engine, like I mentioned before...
Old Sep 10, 2004 | 05:47 PM
big hoss 29
Yeah, I agree with you there. I found out that my neighbor has a friend that has a 74 Lincoln with a 460 that he's going to let go. I think I can get the engine for cheap, (or nothing), and build it up. Thanks for the input!
