Gas leak?
Old Sep 8, 2004 | 12:50 AM
Charlotte's Avatar
Charlotte
Gas leak?
When I open the tail gate of my 88 Ranger 4x4, I can faintly smell gas. (No, it isn't coming from the cap of the rear tank, or the exhaust pipe, because I checked.) What is it likely to be, is it a big job, and how soon should I get it fixed?
Thanks,
Charlotte
Old Sep 8, 2004 | 05:04 AM
95f150's Avatar
95f150
Do you see a puddle on the ground below the tank? I had a leak in my tank and i wiped it clean with brake cleaner then siphone out the gas into a jerry can, used jb weld to fill in the small pencil line crack. Its been holding up for over a year now. And yes you should fix it asap. I used to carry a jerry can in the back of my truck, it came in handy to get me home when i ran out of gas.
Old Sep 8, 2004 | 09:47 AM
G2IC_Wraith's Avatar
G2IC_Wraith
Any gas leak can be dangerous. I wouldn't smoke, or light any matches back there. Once you check for a puddle like 95f150 said, if you don't see anything then you can slide underneath and use you nose. A flashlight and some rags might come in handy too.
If you find it is mostly in the back, then I would tend to believe it is the rubber hoses for the feed and return lines on the top of the tank. If you just can't tell, and you want to be sure, pull the bolts (about 6) from the bed, disconnect the filler neck behind the gas door, and electical going to the lights so you can lift the bed off.
Old Sep 8, 2004 | 05:28 PM
Charlotte's Avatar
Charlotte
There is no puddle at all there, and not a strong smell, just a wiff, but I will get under there and take a closer look. BTW, what is jb weld?
thanks,
Charlotte
Old Sep 8, 2004 | 06:26 PM
G2IC_Wraith
thanks,
Charlotte
JB Weld = poor mans welding alternative. It is a 2 part paste/goo that you mix up and apply to a clean dry surface, and it will dry hard as a rock. It will hold some things as long as it isn't too much stress. You can get it at an auto parts store.
Old Sep 8, 2004 | 06:38 PM
F150'89's Avatar
F150'89
Do you have a gas cap?
Old Sep 9, 2004 | 09:18 AM
pawpaw's Avatar
pawpaw
Charlotte, what event preceeded your beginning to get a whif of gas fumes????
Is the caps gasket ok & in place & are you tightening it up good, after refueling??
Old Sep 10, 2004 | 12:03 AM
Charlotte's Avatar
Charlotte
The same type of thing as "Liquid Steel." What a good idea!
Old Sep 10, 2004 | 12:06 AM
Charlotte's Avatar
Charlotte
Yes, Pawpaw and F150'89, As I stated in the start of this thread, one of the first things I checked was was the gas cap and it aint that. (Not all blonds are dumb, ya know ;^)
Cheers,
Charlotte
Old Sep 10, 2004 | 03:15 PM
F150'89's Avatar
F150'89
[QUOTE=Charlotte]Yes, Pawpaw and F150'89, As I stated in the start of this thread, one of the first things I checked was was the gas cap and it aint that. (Not all blonds are dumb, ya know ;^)
Opps, My Bad
