I need a 6 disc cd changer that hooks up to the factory radio for a 2001 crown vic. Does anyone know where to find them besides e-bay and the dealer? Thanks, oh it is the 12 pin one.
Are you looking for a stock unit or after market unit? I would say go with the after market unit. There are adapters that you can use to intergrate after market CD changers with stock radios.
I was looking for an oem unit, although it does not appear that my deck even has the wires for a cd changer. The deck is a cassete but it also has all the buttons for cd operation.
If Your Radio Has Cd And Shufle Butons Your Ok Call Crutchfield Thell Tell You The Cables And Changer Buy The Cable From Them Then Shop On The Conputer Get It Cheap Their Cable Is $100 Havent Found A Cheap One
I got the cable to install a cd changer in my daughters explorer from www.radiosandmore.com
It was the cheapest I found.You just have to run it from the changer back to the amp. If you cant find what you need on the website you can call them. I was not sure which cable I needed. I told the technician what I was doing and he set me up with the right cable.Hers only had the cassette so I had to change the dash unit and get cd changer.
