Bronco II Ford Bronco II
Aerostar engine in Bronco?
Old Sep 7, 2004 | 08:15 PM
JF1474's Avatar
JF1474
Does anyone know if the 3.0 Aerostar engine is set up the same as the Bronco or Ranger 2.8 or 2.9? How about using the 3.0 short block with the heads, intake and ecu from Bronco or Ranger?
<!-- / message -->
Old Sep 8, 2004 | 06:32 PM
admiralturbo's Avatar
admiralturbo
I believe the bellhousing pattern for the 3.0 is different than the 2.8/9.I have been researching swapping in an SHO 3.0 and folks say I'll need the tranny out of a 3.0 Ranger.But for the hassle of engine swap,unless you have the van 3.0 handy,and nominal power gain with a mortal 3.0,go with a 4.0 or a 302,3.8 from a taurus/thunderbird may be an option or a turbocoupe L4 may be an interesting bolt in.I am pretty sure that all of the above engines will bolt in with at most a tranny,rad,driveshaft swap
Old Sep 8, 2004 | 08:36 PM
JF1474's Avatar
JF1474
Yes I have an Aerostar with a bad trans. That would be the only reason I would use the 3.0. I have found several Broncos with bad motors and was wondering if the Aerostar engine would go right in.
