460 loses power
Old Sep 7, 2004 | 07:15 PM
Dairyf350crew's Avatar
Dairyf350crew
Question 460 loses power
I was pulling our trailer home on sunday and back to Sacramento from Reno up the Donner Summit. I usually go at 45-47 mph; however, i was down to 35 mph by the time i reached the summit. I have a F350 crew cab 4-wheel dually with a 460, c-6, and 410 gearing. I was pulling the same weight as many times before, 32ft alpha toy hauler, estimated weight of truck and trailer at 13,000 lbs. Can anyone give me ideas of what my problem may be? Thanks
Old Sep 9, 2004 | 03:11 PM
Psychods's Avatar
Psychods
It might be your fdm.
On my 96 f250, pulling my 33' 5th wheel from Sacramento to Reno, I lose power while using the front tank. Using the back tank, I can manage 50ish.
The 250 has a 7.5l, banks kit and 4.10 gears. (2wd though )
Old Sep 11, 2004 | 05:46 AM
mpmccarthy's Avatar
mpmccarthy
Seems like 460's are famous for losing power.
I have a 1988 460 / c6 / 4:10 on a motor home and suffered a severe loss of power over time. What year is yours?
Found plugged Cat. Evidently it had been getting worse with time. Finally the engine would barely run. Knocked the guts out of the cat and it was like I had a new engine. I installed a new cat. Wish I hadn't.
Then I started messing around with getting more power. New plugs, wires, K&N air filter, adjustable fuel pressure regulator, etc. Also checked all of the TSB's for my year and found several that needed to be addressed to get the thing to run right. depending on the year of your 460 you may need to look at the TSB's to correct the problem.
Hope some of this helps.
RustyTub
Jan 28, 2015 12:23 PM
truckeemtnfords
19
Jun 18, 2014 02:21 AM
nlemerise
15
Apr 22, 2012 03:59 PM
IDMooseMan
Jul 1, 2007 06:16 PM
j29teamtahoe
Jun 18, 2003 02:04 AM
