Taking a look at the transfer case under my truck today. Need to replace fluid. Where can I get the tool to remove the screw/bolt with the square pattern?
It's not a torx or allen key. Can I get this a Autozone or a similar place?
I think you folks are talking about the fill plug. If you want to replace the fluid you are going to have to remove the back cover on the transfer case. It is an easy job. Remove all of the bolts except the top one which you should just loosen. Pry the bottom of the cover off with a screw driver. Let the old rear end fluid drain. Remove the cover and clean all of the old RTV off. Clean the mounting surface as well. Put new RTV on the diff cover and replace it. Fill it up with straight 80W90 unless you have a limited slip diff.
