EFI manifold compatiblity?
Old Sep 7, 2004 | 04:36 PM
Yakk's Avatar
Yakk
A coworker has a 1988 7.5L that needs replaced, and he has a line on an older carbed engine.
I have reason to believe the Carby cylinder heads may not match up with the EFI intake bolt pattern.
Is this an issue? Solution?
Any other possible concerns would be nice to know.
-J-R-
Old Sep 7, 2004 | 10:45 PM
c_rossman's Avatar
c_rossman
The manifold will bolt up but the ports dont line up.
Old Sep 8, 2004 | 01:01 AM
81f2504x4's Avatar
81f2504x4
how far off
how far off are the port like far enough off to require major work to line up or just a little grinding?
Old Sep 8, 2004 | 06:12 AM
c_rossman's Avatar
c_rossman
I have seen people use Devcon to build the bottom of the ports up a bit and then file it flush with the manifold. That is putting an EFI Intake on a carb motor.
