1978 - 1996 Big Bronco
5 to 8 lug
Old Sep 7, 2004 | 12:14 PM
HAMMER DOWN's Avatar
HAMMER DOWN
Thumbs up 5 to 8 lug
is there any way to make a 5 lug dana44 to a 8 lug would i jut have to change the rotor
other than 8 lugs and the hevy duty brakes is there any diffrence between the 1/2's and the 3/4 ton dana 44's
woudn't mind a dana has any one donethis conversion on a 79 are some were close
Old Sep 7, 2004 | 12:37 PM
Kemicalburns's Avatar
Kemicalburns
why are you going 1 ton in the rear? if so might as well replace the front with a 1ton as well. you wont gain any strength going to the 8 lug ends but still have the 1/2 ton hardware.
Old Sep 7, 2004 | 01:29 PM
HAMMER DOWN
ive got a 60 in the rear what would be involved with putting a 60 up front
Old Sep 7, 2004 | 01:31 PM
Kemicalburns
well you have 2 choices. swap over to a leaf sprung front end or stayin the coil route up front . I would say go with leafs personally.
Old Sep 8, 2004 | 07:04 AM
RTM's Avatar
RTM
Just pick up an 8 lug 44 from a 3/4 ton truck and swap over the outer pieces from the calipers out. I think the axle shaft may or may not be different but you can compare these items during the swap. Another way to see if they are the same is to cross reference part numbers.
Old Sep 8, 2004 | 02:56 PM
HAMMER DOWN
the bronco and f150 frames are siffrent than the 250s and 350s am i right
Old Sep 8, 2004 | 03:15 PM
RTM's Avatar
RTM
Yes and that goes for all years if I am not mistaken.
Old Sep 8, 2004 | 04:42 PM
HAMMER DOWN
so it would probly be easyer to mount the dana 60 on the coils thank to hang it on leafs
Old Sep 8, 2004 | 08:22 PM
RTM's Avatar
RTM
There are people that have done the install both ways. Some like the coils better than the leaf spring set up. To install the leafs there is some major frame mods that have to be done but the 60 front axle will need some work as well. Try searching the site for the info before asking. If you can't find what you need by searching then state that in your post. good luck
Old Sep 8, 2004 | 08:36 PM
HAMMER DOWN
thanks for the info
