Squeaky Belt
Old Sep 6, 2004 | 11:12 AM
dmarple's Avatar
dmarple
Squeaky Belt
Hi Folks
1999 Explorer, 46,000 miles, extended warranty, in shop for minor repair. Informed that serpentine belt needed replacing. We authorized it. Now when car starts belt (I assume) squeaks. No squeak prior to replacement. Is this something that can be caused by incorrect repalcement ? Is there a simple fix or should it go back to shop ?
Thanks
Regards
Dennis
Old Sep 6, 2004 | 01:42 PM
87 XLT's Avatar
87 XLT
To se if it IS the belt spray a little water on it & start it up. If the noise is gone it is the belt. Maybe a different brand of belt would be quieter.
Old Sep 9, 2004 | 09:43 PM
02ExplorerXLT's Avatar
02ExplorerXLT
Theres a chance it may be a bearing or 2 in one of the pulleys.
Old Sep 9, 2004 | 10:59 PM
85e150's Avatar
85e150
Yea, the idler likes to take flight from time to time....If you're lucky, you can do it while in warranty & have it take out the radiator, fan, waterpump so Ford can give you all that stuff free too just before your warranty pies.
Signed,
Cynical Explorer Owner
Old Sep 11, 2004 | 02:46 AM
hellktn's Avatar
hellktn
Cool me too!!!
I've had a constant whine that's progressingly getting worse in my '99 xlt V8 Explorer!!!
I can't even see the tension pulley to check if it's with-in range because the F'd placement.
Since Aug. '99 when I got it - nothing but problems! Hate it!!! I'm assuming it's the power steering pump but who knows?!!! Might be a pulley or bearing! If someone could give another suggestions, please do.
