horsepower
Sep 6, 2004 | 12:09 AM
horsepower
i have a 1995 ford f-150 eddie bauer with a 5.8L(351c.i.). i was wondering if anybody knew how much horsepower it had. i have seen some stats and i would like to see if anybody else had an idea.
Sep 6, 2004 | 12:32 AM
Should be about 215 HP @ about 4200 rpm.
Sep 6, 2004 | 06:53 PM
kinda low dont you think? and the real question would be how many ft lb of torque does it have?any one know on the 302 how much of both?
Sep 6, 2004 | 09:13 PM
Sep 6, 2004 | 10:06 PM
351 torque peak is at 2800 rpm. Dont remember how much, sorry.
The only 302 power specs I have are for '69 motors.
Sep 6, 2004 | 10:24 PM
302: 185 hp @ 3800 rpm and 270 lb.-ft. torque @ 2400 rpm. These numbers changed a little when they put roller cams in the trucks.
Sep 6, 2004 | 11:01 PM
With the roller cams..the 302 has 205hp @ 4000 rpm and 275ft-lbs @ 3000 rpm.
351 has about 310 ft-lbs.
Sep 6, 2004 | 11:23 PM
when were the roller cams first installed
Sep 6, 2004 | 11:47 PM
302 HP 185
TQ 270
351 HP 240
TQ 340
i got these numbers off of cars.msn.com the 302 enigne was under the year 1990 and the 351 was in 1993.
Sep 6, 2004 | 11:51 PM
That's the highest 351 horsepower and torque rating I've seen for the '90's trucks. Are you sure those aren't passenger car numbers?
Sep 7, 2004 | 12:35 AM
no i am sure these were under f-150 but i dont know they could be wrong the best place to look is in the chilton guide.
Sep 7, 2004 | 12:47 AM
i could have sworn a 351w from the '90s was 210 hp 315 ft lbs. i remember those because the cheby 350 was rated at 200 hp and 310 ft lbs.
Sep 7, 2004 | 01:12 AM
Sep 7, 2004 | 01:41 AM
that was great helped alot
Sep 7, 2004 | 03:10 AM
The haynes manual or chiltons I believe says 210hp and 315 or something for torque...it's definitely not 240hp for hte 5.8.
The rollers started somewhere around 93-94...
