Aerostar Ford Aerostar
Cruise Ctrl/Tranny Problem
Old Mar 27, 2002 | 08:40 AM
TallPaul's Avatar
TallPaul
Went on a 400 mile trip in a co-workers Aerostar. It is a 3.0, about a '95, with 120,000 miles. Anyway, he will run cruise control for a while, then cruise will shut off by itself. After that the tranny will shift back and forth between 3rd and 4th gear, staying for a couple seconds in each gear, then it runs for a while (minutes) in 3rd (or 4th without the lockup) because you can hear the motor revving (no tach). He said he had the tranny fluid changed not long ago. Anyway, just wondered if anyone had that happen so I could tell him about it.
Thanks
Old Mar 27, 2002 | 08:57 AM
Mikeman's Avatar
Mikeman
I've never had this happen, but a couple things that affect OD/lockup and cruise control come to mind. The brake on/off (BOO) switch will unlock the torque converter and will also turn off the cruise when the brake pedal is pressed. Throttle position is used in 3-4 shift and torque converter lockup scheduling. Check both of these out and see if they're bad.
Old May 6, 2002 | 11:52 AM
TallPaul's Avatar
TallPaul
Thanks for the response. I forwarded it him, but never heard back, which suggests he never checked it out.
Old May 6, 2002 | 11:03 PM
biederboat's Avatar
biederboat
CDNMuddawg
6.7L Power Stroke Diesel
Sep 18, 2015 06:26 PM
pilgrimbizket
59
Jul 29, 2015 10:02 AM
joelswork
Nov 4, 2010 05:54 PM
HawaiianPSD
1983 - 2012 Ranger & B-Series
Nov 30, 2006 02:49 PM
the tank
Apr 16, 2004 10:40 AM
