Changing plugs
Old 09-05-2004, 06:19 PM
stlthf1's Avatar
stlthf1
stlthf1 is offline
Changing plugs
I just bought some Denso plugs but I can't seem to find a socket that will take out the stock plugs. They are recessed into the head quite a bit.
Does this take a special tool?
Thanks,
Jon
Old 09-05-2004, 11:09 PM
Black4.2's Avatar
Black4.2
Black4.2 is offline
Thats odd, I use a regular spark plug socket(with rubber insert
) to remove my plugs.
Old 09-06-2004, 08:23 PM
BrianA's Avatar
BrianA
BrianA is offline
Same as above ^.
Standard spark plug socket = no problems for me.
Old 09-06-2004, 10:12 PM
stlthf1's Avatar
stlthf1
stlthf1 is offline
I didn't try one of those. I figured a regular sized socket would work. Maybe the walls are too thick compared to the plug socket with the rubber in it. Thanks for the help.
Jon
Old 09-07-2004, 09:50 AM
true4.2's Avatar
true4.2
true4.2 is offline
You are using a long socket right? Not a short socket?
Old 09-07-2004, 10:40 AM
stlthf1's Avatar
stlthf1
stlthf1 is offline
LMAO...uhhh...yeah.
Jon
Old 09-07-2004, 04:05 PM
Black4.2's Avatar
Black4.2
Black4.2 is offline
Well if you do end up using a regular socket, be careful. The rubber insert helps to keep them from cracking. Cracking one of those new plugs would not be fun.
Old 09-07-2004, 10:46 PM
stlthf1's Avatar
stlthf1
stlthf1 is offline
uhhh..no. They aren't cheap. They are Denso's so cracking one of them would be a costly mistake.
Thanks,
Jon
Old 09-08-2004, 09:18 AM
true4.2's Avatar
true4.2
true4.2 is offline
Originally Posted by stlthf1
LMAO...uhhh...yeah.
Jon
LMAO...uhh...good.
Old 09-08-2004, 04:13 PM
homer4.2's Avatar
homer4.2
homer4.2 is offline
hey now hey now, hahaha
