Aerostar Ford Aerostar
Changing Thermostat
Old Feb 24, 2002 | 09:04 PM
wildjon300ci's Avatar
wildjon300ci
Changing Thermostat
Now hoe the heck do you get to the thermostat on these things?...92 4.0L Aerostar...I need to replace the one on my Mom's van 'cause it is stuck open, but I don't have the slightest clue how to get in there without dissasembling everything. Stupid Vans!
Old Feb 25, 2002 | 01:51 AM
asavage's Avatar
asavage
FTE Community Team
Changing Thermostat
I just replaced the thermostat, rad hoses, heater hoses, and radiator fan (plastic was cracking around the hub) today, on a '92 Explorer w/4.0l . The engine is the same as the Aerostar's, but access is better.
On the explorer, the thermostat housing is also a stamped sheet metal pipe that goes 90 degress up, then curves to the passenger side, where the upper rad hose connects, routes behind the alternator, then forward to the radiator. I do not know if this is the same routing as in the Aerostar.
I used a 1/4" drive ratchet, 3" extension, and 10mm deep socket to remove the three bolts retaining the thermostat housing to the front of the intake manifold. The upper passenger side bolt was a PITA! The crank position sensor wire harness is routed directly in the way, and there's very little room to shove it to one side, but I managed.
When putting the housing back on, hang that bolt loose in the housing before putting the housing in position, it's the only way (that I could see) to get it started. The job went OK.
This rig took forever to warm up, and the temp gauge liked to hover near the "N" of the "Normal" range; now it heats up much faster, and runs mid-range of the scale like it should.
The sealing fat o-ring goes on the housing side of the thermostat. My thermostat housing was a bit corroded, so I cleaned it up then put a very light coat orange RTV on it, just to fill in the corrosion pits. Doesn't seem to leak.
BTW, Aerocolorado, on the subject of fan clutches: the early Aeros with two belts drive the water pump via the grooved side of the belt, and use left-hand-threaded fan clutch mountings; the later 4.0l use the single belt accessory drive, drive the water pump from the back side of the belt (and, therefore, in the opposite direction) and use the right-hand-threaded fan clutch mounting. I had a couple side-by-side in the driveway today, and it's obvious, once you think about the way the two different drive systems drive the water pump in opposite directions.
I wonder what the later 3.0l pumps look like, and if they drive the water pump from the grooved side or the back side of the belt?
Regards,
Al S.
Old Feb 25, 2002 | 07:27 AM
Avanti's Avatar
Avanti
Changing Thermostat
When I changed mine out on a 94 4.0 with rear heat I also had to disconnect the metal heater hose lines top bracket from the block. Just push it a little out of the way. The rest is like the guy before said. Also the 4.0 Aerostars tend to trap air in the system so it needs to be bleed after you do this.
Old Mar 29, 2002 | 02:06 PM
gunner17's Avatar
gunner17
Changing Thermostat
Old Jul 7, 2002 | 07:13 PM
Edward C's Avatar
Edward C
Changing Thermostat
When you changed the thermostat on your van. Was the removal of the clutch fan assembly required? Also did you need to replace the plasic fan blade?
Old Jul 8, 2002 | 02:45 PM
biederboat's Avatar
biederboat
Changing Thermostat
On my 93 4.0 AWD didn't have to remove the fan components. Best to go in with 1/4" drive, the left most bolt is the tough one.
