Check engine with 224 code
Old Sep 3, 2004 | 01:41 AM
TexasRanger94's Avatar
TexasRanger94
I'm running a '94 Ranger with a 2.3L, 5 speed. Came up with the check engine light earlier this week. Pulled the code using the flashing check engine light method from the Haynes manual and then had it verified at AutoZone. I can't find any reference to SPOUT in the Haynes so I'm not sure what or where it is. The code manual the guy at AutoZone used said to look at the coil packs. I've checked the primarys and secondarys in each coil and they ohm out exactly as the manual says. Reading through the other postings I've seen Ken00 make reference to a pinpoint check. Is that the next road I need to take or is there something else to do first? If it's the pinpoint check, where do I find it? Thanks.
Old Sep 3, 2004 | 10:21 AM
Vin 95's Avatar
Vin 95
it stands for "spark out"I think its a reference to the spark out wire to to coil pack from the PCM.
Old Sep 3, 2004 | 10:26 AM
Vin 95's Avatar
Vin 95
Check your haynes wireing diagram,"ignition system circuit"It shows the spout check connector going from the PCM to the ignition control modual.
Old Sep 3, 2004 | 09:14 PM
Ken00's Avatar
Ken00
Just let me know if you want the pinpoint tests, ask me for PPT JC. You'll need a multimeter & 2 breakout boxes.
Old Sep 6, 2004 | 10:30 PM
TexasRanger94
Hey Ken,
Yes, I would really appreciate it if you could send me the PPT JC. I've got the multimeter (I'm an electronics tech by trade). Are the breakout boxes purchase items or do I need to build them? Thanks.
Old Sep 6, 2004 | 10:36 PM
TexasRanger94
I don't know if Ken00 rereads threads he's already replied to. I tried to send him an email requesting the pinpoints test, but I don't have enough posts yet for my email to be enabled. Could one of you kind folks out there let him know? I appreciate it.
Old Sep 7, 2004 | 07:20 PM
Ken00's Avatar
Ken00
I read all posts in this & the BII forum, you have mail.
danwtx
1997 - 2003 F150
Nov 11, 2014 05:13 PM
g_k50
1978 - 1996 Big Bronco
21
Oct 11, 2008 07:48 PM
meck1
Aug 3, 2007 05:04 AM
sandraj
Oct 18, 2004 09:57 AM
derbyit857
Oct 6, 2004 05:33 PM
