timing and ignition q's?
Old Sep 2, 2004 | 08:37 PM
84FB351's Avatar
84FB351
i just swapper in the duraspark ignition system in my 85 and got rid of the other junk. i could not figure out the igniton though there should be 2 power wires 2 coil wires and 2 distributor wires right? anyways i ended up puttin g i n a temporary msd ignition and went to time it and there was no mark showing up so i took the light and looked underneath the truck and sure enough the mark is dirextly below the pointer what would cause this?
Old Sep 3, 2004 | 03:21 PM
PaulzF150's Avatar
PaulzF150
When you did the swap and changed the distributor, did you index the rotor on the #1 cylinder, on the compression stroke, before you removed the old distributor?
