Aerostar Ford Aerostar
Headlight Replacement
Old May 31, 2002 | 10:44 AM
90Aerostar's Avatar
90Aerostar
Does anyone have instructions on how to remove the headlights?
I need to replace the passenger side light, but having trouble removing the old one? Anyone have pics and instructions?
Also, is there a fix for the DRL (Daytime Running Lights)? Ford had replaced my unit once, but the thing has burned out again. Has everyone else had the same problem?
Thanks
Old May 31, 2002 | 09:46 PM
nitro94's Avatar
nitro94
On some of the earlier models it was easiest to remove the bumber cover. Not nearly as hard as it sounds.
Old Jun 4, 2002 | 10:45 AM
JimmyK1957's Avatar
JimmyK1957
[updated:LAST EDITED ON 04-Jun-02 AT 11:47 AM (EST)]I've had 2 DRL modules go bad, so on my 94 I replaced the daytime running light module with a jumper plug from an Amercian unit. It fits into the same connector as the module. No DRL lights, but my highbeam indicator works like it is supposed to.
I remove the headlight assembly on mine by first removing the turn signal/trim assembly, (2 torx screws and a couple for plastic ones), and then remove the 4 screws that hold the headlight in. I think 94s are a bit different than 90s though, I have the big plastic headlight, not sure if 90 is the same or not.
Old Jul 17, 2002 | 08:28 AM
BrokenSockets's Avatar
BrokenSockets
Do you have the part number for that jumper? I have gone through three DRL modules in the past few years plus five more that I got from the wrecker that turned out to be no good. I would really like to do away with it.
Old Jul 24, 2002 | 02:46 PM
JimmyK1957's Avatar
JimmyK1957
P/N fo the jumper is F0FZ-14489-A.
Old Jul 27, 2002 | 08:54 AM
CdnSoldier's Avatar
CdnSoldier
If you are living in Canada, you require Daytime lights on some yrs. Its a 103$ ticket and if you have to get a safety it will not pass. I know when I got posted to another Province they would not pass it. The problem will the modules is it maybe in the wrong spot (heating up), or you have a short from your lights. PS how can I put in a Signature block, I tryed evry thing? I'm not a Computer dumbie but you know things sometimes fail.
Cdn Soldier
Old Jul 29, 2002 | 02:09 AM
dzk007's Avatar
dzk007
Old Jul 29, 2002 | 02:16 AM
dzk007's Avatar
dzk007
Before removing the headlight, it's easiest to remove the grill. Then the corner light, then the headlight. This all is real easy!! but prevents breaking things from haste.
Soldier, Edit your profile till you get it right
