Aerostar Ford Aerostar
Thunk in rear end
Old Jul 28, 2002 | 10:37 PM
biederboat's Avatar
biederboat
Thunk in rear end
I just replaced the rear axle on Aero #2 (93 AWD). There is a "thunk" that I'm certain is coming from the upper control arm that keep the axle in proper alignment to the drive line (connects next to the right top side of the diff. housing & up to body with two points). There is a gap that shifts when the body bounces. It's independant of accell/decell so it's not inside the housing. Should this gap be taken up by compressing the joint? When I pulled this large bolt out, the threads got a bit buggered up and not sure how tight I can get it. I can't check against my other Aero as it's still awaiting the tranny rebuild to be complete.
Can someone go out and have their wife bouce on the bumper and check to see if there is any slop in this joint? I hesitate to just crank on it as the bracket appears to be cast and might break. Would this mean that the bushing is worn?
Thanks,
Mark
Old Jul 29, 2002 | 02:09 AM
dzk007's Avatar
dzk007
Thunk in rear end
Yeah Mark, There should be no slop in the control arms of any suspension parts on the front or rear. Take the hit on the new bushing kit and do it right. otherwise, you may not like where it strands you.
Old Jul 29, 2002 | 09:14 AM
MO51's Avatar
MO51
Post Thunk in rear end
My 96 had this symptom, that three legged bracket that connects front of rear axle with the frame had eaten the rubber bushings. I couldn't find a bushing kit, Ford (in Sacramento) only sold the new bracket and bushings together. ($300)
Old Jul 29, 2002 | 09:36 AM
biederboat's Avatar
biederboat
Thunk in rear end
Thanks guys, I'll do it right and get her fixed.
Mark
Old Jul 29, 2002 | 07:27 PM
chaddsdad's Avatar
chaddsdad
Thunk in rear end
RAY1986F150
22
Nov 3, 2011 08:57 PM
jkidd_39
16
May 27, 2010 01:39 PM
bbabb
May 1, 2009 04:24 PM
Buggie
20
Feb 12, 2006 11:44 PM
Crystal
Aerostar
Feb 12, 2002 10:55 AM
