Buying a ford
Old Sep 2, 2004 | 03:09 PM
Ford Truck Man 04's Avatar
Ford Truck Man 04
Question Buying a ford
Hi,
I'm thinking about buying a '82 F150 that I saw in the paper. what should I look for before buying it?(I know the common things)
Nathan
Old Sep 2, 2004 | 03:40 PM
FordPickupMan351w's Avatar
FordPickupMan351w
With the older trucks, I would say that body and frame rust take a big part in the inspection. Next thing to check is the engine and transmission, also if it has 4wd try engaging it and going in a circle. If the tires do not jump then it is not working properly. Watch whenever you start it and see if it is smoking or anything. Use your best judgement and take it for a spin. If it rides nice and sounds decent then most the time the truck is worth it.
Old Sep 2, 2004 | 07:23 PM
Big ole Dog's Avatar
Big ole Dog
Get the truck up to running temp what the oil pressure do does it stay close to the same when hot and cold pull the oil cap hose from the breather or pcv vavle does it have any blowby Can you run a comprassin test on it? You can park it on a fresh piece of concret look for leaks Check the rear end for heavy oilaround it what does the bottom of the truck look like Coated with motor oil? If yes the could be rear main seal or oil pan. If it has transmisson fluid the look at it and check the oil pan or dipstick tube .How does the truck drive can you drive one tire over a speed bump and listen for a bump under your feet Look at the seals on the tie rod ends orball joints are they there it check compants with a bar for slack or jack up the front wheels when you move it left and right or up and down. I like to get to know the truck and get a second opinen if in doubt
Just me and my ways
Old Sep 2, 2004 | 08:26 PM
Lee Lichterman's Avatar
Lee Lichterman
Sorry to butt in but what does this tell you? I have never heard of this check. Hot oil runs easier so checking for restrictions in passage ways or loose bearings causing a drop when it gets hot? You caught my attention.
Good Luck,
Lee
Old Sep 2, 2004 | 08:44 PM
Big ole Dog
Ever heard of the old carlot trick of putting 20w-50w oil in a wore out motor sure it has good oil preasure when cold but when it gets hot and at a idle it drops to nearly nothing
Old Sep 2, 2004 | 08:50 PM
Lee Lichterman
Ahhhhhhh! OK, I was thinking normal oil.
Thanks,
Lee
Old Sep 3, 2004 | 02:30 PM
Ford Truck Man 04
Thumbs down
thanks for all the input. i'm not going to buy it I called the guy, and he said that the body was pritty bad. the engine had been rebuildit in '95. the real problem I had with it is that it had a auto trans.(I hate autos!!!!!)
