Aerostar Ford Aerostar
engine code 24 : help to locate the ACT sensor
Old Jul 28, 2002 | 09:07 AM
tomyu's Avatar
tomyu
94 3.0 w/AC
symptom: in "park" idle hestitation, engine cut in/out, the volt meter needle up & down. No problem after shift to "drive" and normal on the road driving.
Replaced PCV valve and air filter. Same problem.
Brought the code reader, show 24 error code. ACT/IAC out of range.
1,where is the ACT/IAC on the 3.0l, my hanes manual have no pic for 3.0
2, can I use computer electronic cleaner to wash the sensor
3, is the sensor part expensive to replace by dealer?
Tom
Old Jul 29, 2002 | 10:29 AM
aerocolorado's Avatar
aerocolorado
You are dealing with two separate sensors.
The ACT (air charge temperature sensor) is located on the intake plenum and resembles the water temperature sensor in looks and connector (2 wire). I doubt if this is your problem.
The IAC (idle air control valve) is the most like suspect and is a common problem in these engines. It is a cylindrical affair attached to the throttle body, again with a two wire connector. It is a simple electromagnet controlling a pintle pin, the pin in turn controlling the amount of air into the throttle body in response to engine load conditions. I.E. when idling and you activate the A/C system, the additional load imposed by the compressor causes the electronic brain to send a signal to the IAC valve to step up the idle to compensate. Under normal (no load) idle conditions the valve should be completely closed. Wear and/or deposit accumulations prevent the pin from closing the valve completely, which is why you experience the surging type of idle at rest but find it normal when in gear (under load). Just unscrew the two mounting bolts, with draw the IAC valve unit and try cleaning with a carb cleaner type solvent. The electronics cleaner won't hurt it but may not help if the gum deposits are not removed.
Expense wise, the ACT runs around $14.00 new and the IAC can run anywhere from $45 to $75 depending upon the source.
Old Jul 29, 2002 | 08:21 PM
tomyu's Avatar
tomyu
Great information, I can I.D the modules I'll find time this week to fix it. Thanks.
Old Jul 31, 2002 | 09:00 PM
tomyu's Avatar
tomyu
Thanks aerocolorado... the idle problem fixed with your advice. Rinsed all the dirt out from the IAC with carb cleaner.
Tom
Old Aug 1, 2002 | 12:17 AM
JanR's Avatar
JanR
Post engine code 24 : help to locate the ACT sensor
ajnilson
15
Jul 29, 2024 02:07 PM
kegomatix
Escape & Escape Hybrid
Mar 4, 2017 06:32 AM
jmsbtz
Jul 19, 2016 07:53 AM
Zorfox
Jul 24, 2015 12:30 PM
cadriver
1983 - 2012 Ranger & B-Series
30
Apr 5, 2007 08:34 PM
