Custom Cab? What does it mean?
Old Sep 1, 2004 | 06:56 PM
58shortbed's Avatar
58shortbed
I've had my '58 big window shortbed styleside for almost a week now, and I'm curious what "Custom Cab" refers to. I've seen others list it in their posts, and mine is a Custom Cab, but I don't really know what that means.
thanks in advance for your replies!
TC
Old Sep 1, 2004 | 07:36 PM
mr4speedford's Avatar
mr4speedford
Custom Cab trucks all got stainless windsheilds trim(and the trim around the back window), chrome grille, the option of now getting two-tone paint, thicker seat, different seat pattern and two visors. I know 59-60's get the dressier guage panel and horn/steering wheel, but I'm not sure about the 1958's. -4speed
Old Sep 1, 2004 | 07:45 PM
StarFox's Avatar
StarFox
Mr 4Speed covered much of it, the Custom Cabs had a little extra pizzaz, if you will. Didn't the Custom's also come with an arm rest on the passenger side door as well?
Old Sep 1, 2004 | 08:04 PM
kooper909's Avatar
kooper909
Don't know about the armrest .. the regular cab didn't include any armrests standard. Mine has none.
Old Sep 1, 2004 | 08:43 PM
58shortbed's Avatar
58shortbed
My Custom Cab apparently HAD an armrest on the driver's side standard, but it is long gone. Speaking of long gone, both of the side windows (roll-up) are gone too. Any suggestions where to get them cheap with the chrome edges? As far as I can tell, the roll-up mechanism is still there.
thanks!
TC
Old Sep 1, 2004 | 10:29 PM
ms_michelle's Avatar
ms_michelle
I don't know about 57 and up, but in 56 you also got a lock cylinder in the drivers door, standard models only had the lock cylinder on the passenger door.
Michelle
Old Sep 1, 2004 | 10:30 PM
kooper909's Avatar
kooper909
I'm pretty sure armrests were a separate option.
Old Sep 2, 2004 | 09:30 AM
Sixoh's Avatar
Sixoh
....also, the big window was an option on both Custom Cab and Standard Cab. I have a feeling the door locks and the arm rests were options as well?
Old Sep 2, 2004 | 06:51 PM
StarFox's Avatar
StarFox
I seem to recall the same info posted about door locks previously, ms michelle, you are probably right about that.
Old Sep 2, 2004 | 08:20 PM
nixer's Avatar
nixer
i dunno why they put a lock only in the pass side door. last time i checked the driver usually sits on the other side of the truck lol
Old Sep 2, 2004 | 08:41 PM
mr4speedford
Door locks are correct. As is the arm rest. I knew there was things I was forgetting. FTE is my cure for memory loss! Interesting fact, standard cab big windows still had rear window trim! -4speed
Old Sep 2, 2004 | 09:12 PM
CIAF's Avatar
CIAF
Nixer, Back in the day, all or most city streets were 2 way streets and it was illegal to exit a vehicle from the driver's side so a lock on that side would be worthless. People were to lock ds from inside, slide across and then lock ps from outside. ( No buckets,no consoles) And, out in the country (rural areas) locks were not even used. As cities grew, one way streets were added to better move traffic, so folks were able to park on the left side of street and exit the drivers side and locks were added. Automotive History 101 , Chapter 6. Sub. 4, Locks. So there.
PS: Got my corners and lock welded in and doors rounded.
Old Sep 5, 2004 | 09:01 PM
soupy264's Avatar
soupy264
it included padded dash, white steering wheel with horn ring,and the above fancies
F250racer
Apr 28, 2010 01:11 PM
My58Ford
Mar 21, 2007 07:49 PM
58shortbed
Oct 19, 2004 10:17 PM
58shortbed
Oct 12, 2004 01:07 PM
