having wiring problems
Old Sep 1, 2004 | 04:05 PM
fatpimp_927's Avatar
fatpimp_927
Question having wiring problems
I am having trouble with the wiring between my alternator and battery. The truck will only run off the battery and the alternator has been checked and it is good. The alternator light will not go off. The solenoid is good the voltage regulator is good. Can anybody help me figure out the problem with this newly purchased project?
Old Sep 1, 2004 | 09:44 PM
DAV1972's Avatar
DAV1972
Check for a good clean connection on the field (orange) wire off the alternator.
Old Sep 2, 2004 | 05:16 AM
Fritolay's Avatar
Fritolay
get or borrrow a good multi meter test for continuity trrough your wires make sure that if your harness has in line fuses that they are not blown out and that the wires themselves are in good condition
