Lookin' for info.
Old Aug 31, 2004 | 05:46 PM
Goodold71's Avatar
Goodold71
Lookin' for info.
I am looking for info. on 67-72 trucks . I own a 71 f100 4x4 that sports a np435/dana 21 trans/tcase.It has a 360 FE engine. I want to put a c6 in her. What years and what trans/tcases options do I have. I was told the c6 behind the 360 FE had a dana 21 also not the most revered np205 tcase.Is this so? Can I put a np205 tcase behind a c6 that mates to a dana 21 by changing shafts? I just want to put a c6 behind my FE because of recent knee injury and less abilityt to shift.All help welcome.
Old Aug 31, 2004 | 06:43 PM
Enthused'71f1004x4's Avatar
Enthused'71f1004x4
This may help somewhat:
http://www.fordtrucks.com/forums/sho...d.php?t=252012
worked for me anyway. Just in case... the 390 has the same block so you need a C6 with a bell housing for a 360 or 390. I had to swap the extension housing on the '78 C6 I bought to marry properly to the NP205 i had. I hocked the extension housing form an old bronco. that's the fun of modified though I guess. I have the Ford 9" 10 bolt rear so I can't comment on the Dana 21.. Good luck!
Old Sep 1, 2004 | 06:15 PM
Goodold71's Avatar
Goodold71
I thought all 67-72 f100 4x4's ( half ton) came with the manual 435/dana 21 tcase and the c6/dana 21 tcase. Can someone please clear this up?
Old Sep 1, 2004 | 06:40 PM
Enthused'71f1004x4
Sorry if I caused any confusion Go71 or didn’t get your question. My truck was built from a 2wd so doesn’t represent factory for 67-72 4x4s.
I just wanted to say that if you were looking for a C6 to bolt onto a 360/90 look for ~’78 C6. Someone else may be able to tell you all of the C6 tcase options.. np205 is definitely one of them.
Old Sep 2, 2004 | 05:22 AM
Fritolay's Avatar
Fritolay
basically find an auto 4x4 from 67-79 that has the tranny and transfer and rip em out cuz they will work if you can get the drive lines.
all the 67-72 4x4 trucks did come with a dana 21 tansfer (yuck) it is rock solid and small but those are about its only good points. i have to back up like thirty to forty feet to get mine to come out of 4x4 glad i just bought me a donor truck with an np205
