speedometer sensor
Old Sep 1, 2004 | 12:18 PM
fet's Avatar
fet
speedometer sensor
A while ago I had asked about my speedometer jumping around. I was told that it could be a speed control part (sensor) located somewhere in or around the rear differential. I have a 1996 E-250 cargo van.
What I need to know is if this is something that I can change myself or not. I'm pretty mechanically inclined but wanted to know more. Like location of part, things to look for etc.
Any help would be apreciated. Thank you.
Old Sep 1, 2004 | 12:26 PM
79_250RangerLariat's Avatar
79_250RangerLariat
I don't know about on the vans for sure...but on my dad's 96 150 it was right on top of the rear pumpkin. Unplug the wire and take out a bolt and it pulled right out.
Old Sep 2, 2004 | 08:20 AM
fet's Avatar
fet
Great, Thanx.
Old Sep 2, 2004 | 09:45 AM
Heaterman's Avatar
Heaterman
My 2000 PSD seems to be 3 mph slower than those radar detector things the cops have on the road all the time around here. I have regular stock tires and wheels. Is this common?
Old Sep 2, 2004 | 11:29 AM
fet's Avatar
fet
If your basing the difference in speed to radar guns, it wont always be right. The guns need to calibrated alot. So I wouldnt use use that as your guide line. Most departments in fact, are required to calibrate the guns before and after evey shift.
Old Sep 2, 2004 | 04:40 PM
CLK's Avatar
CLK
if your speedometer is within 3-4 mph of the actual truck speed you are good, this is a factory tolerance.
Old Sep 3, 2004 | 11:18 AM
fet's Avatar
fet
There ya go! I thought that might be the case but I wasnt sure enough to say something.
P.S. get out and vote!
