Propane injection?
Old Aug 31, 2004 | 11:16 PM
Randyb12's Avatar
Randyb12
Propane injection?
I am considering propane to run my new project. It is a 4x4 that will see some extreme angles. Has anyone ever done this. What is the cost? What are the performance issues? Would EFI be better?
Thanks
Old Sep 2, 2004 | 10:20 PM
Ratsmoker's Avatar
Ratsmoker
I ran propane in a tow truck once. It had a 370 Lima engine in it. I don't know if the 370 is gutless in gas form but it sure was on propane. Propane has less energy than gasoline but has a higher octane so I think you need to have higher than normal compressions to run it. I can't beleive your thread got to the bottom of the page with no replies. I didn't even see it earlier. Wierd!
Old Sep 2, 2004 | 10:34 PM
gtex's Avatar
gtex
Randy, you and Russ should get together and have an "undecided" festival :-) You guys have the always changing projects!
You need to go PSD on your 4x4 project :-) I'm sure that will get me kicked out of the FE forum.
Old Sep 2, 2004 | 11:13 PM
Randyb12's Avatar
Randyb12
Thanks, Sean
Sorry greg, No Desiels. I don't know the first thing about wirking on them. I read that you can run 12:1 CR with lpg. It is supposed to have a octane of 100. I just have never seen a hipo lpg setup. Or any lpg setup for that matter. It was a suggestion from the Off-road forum. Which by the way was very unpleasant. I think they were probly just making fun of me when they suggested this. I won't be going back.
Old Sep 2, 2004 | 11:22 PM
Scouder's Avatar
Scouder
I think you would be much happier with EFI on a gasoline engine. It would be unaffected by angles, give great throttle response, and usually better mileage. Then you can use tried and true engine mods. There was a time in this area when Propane powered trucks were the rage, and everybody who had one was bragging up how cool they were. Interestingly, every person I knew who had one doesn't have one anymore.
-Scouder
Old Sep 2, 2004 | 11:44 PM
Ratsmoker's Avatar
Ratsmoker
I think rusty has done the fuel injection thing and is having good luck with it. That was you right Rusty? I wonder how well those truck avenger carbs actually work.
Old Sep 3, 2004 | 02:39 AM
ZombieSlayer's Avatar
ZombieSlayer
A good friend on mine had a mid 70's F150 4x4 that he ran on propane and gasoline. This truck was indestructable. He never had a problem using propane. He wasn't interested in speed. He would still have the truck today if it wasn't for that drunk driver
I have only seen two or three propane four by's, and Larry's was by far the best. It was probably the exception to the rule from what I've heard since. Just wanted to let you know...it can be done with propane.
Old Sep 3, 2004 | 11:46 AM
rusty70f100's Avatar
rusty70f100
Yep it was me that did the fuel injection. It's a 700cfm Holley TBI system. You simply have a 4-barrel throttle body with 4 injectors on top spraying fuel down into each barrel. It comes complete with the Commander 950 ECU, and all the appropriate speed-density sensors, including an O2 sensor that I welded into the collector. I could see where you could run the thing at any angle needed.
If anyone gets one of these, I'll e-mail you the ECU map I'm using on mine so you can have a starting reference point for an FE. No FE maps are included with the system.
I think it would work great for off-roading.
Old Sep 3, 2004 | 01:20 PM
EgoMan's Avatar
EgoMan
Petersons 4x4 magazine had a truck in it that was all propane for its toptruck challenge last year It still had gobbs of HP.
Old Sep 3, 2004 | 01:32 PM
Randyb12's Avatar
Randyb12
Thanks for all the feedback. I was thinking of simplicaty with the propane. It seems simple from what I have read. Although the donar truck is a 92 F250 with all the EFI stuff. It still has the injectors and fuel rails no engine). I wounder how hard it would be to get my notor working with the factory EFI. Just have to have the intake drilled for the injectors and adapt a throttle body to it. Do you think it would be worth it?
Old Sep 4, 2004 | 12:25 AM
Dealford's Avatar
Dealford
Go Fast Propane
There's a couple of links included.
https://www.ford-trucks.com/forums/s...d.php?t=272731
AL.
