Aerostar Ford Aerostar
grease points
Old Aug 4, 2002 | 07:19 AM
cajunbull61's Avatar
cajunbull61
grease points
Old Sep 1, 2002 | 06:01 PM
dougas's Avatar
dougas
grease points
[updated:LAST EDITED ON 01-Sep-02 AT 07:13 PM (EST)]How many nipples are there to grease on 1990 4.0 aerostar rwd.I have a grinding noise-squeak. when i go over bumps and also when i drive new wheel bearing,calipers,inner tie rod ends,steering rack,upper-lower ball joints.it is not a steady noise rotors turned thanks
Old Sep 3, 2002 | 11:55 AM
aerocolorado's Avatar
aerocolorado
grease points
If your noise originates in the front end, it may likely be the large front sway bar moving against the bushings. Try spraying the rubber busings with a silicone based spray to see if this eliminates your noise. If so, you can try unbolting the bushings and reversing them to gain a temporary fix, but ultimately the bushings wil have to be replaced. Hope this helps.
Old Sep 4, 2002 | 11:05 AM
rebocardo's Avatar
rebocardo
grease points
There are rubber bushings, fairly well hidden, holding the steering rack that can also cause phantom noises when going over bumps.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
