wire route to headliner
Old Aug 31, 2004 | 07:57 PM
hoff's Avatar
hoff
im installing a aftermarket flipdown on my supercrew rails soon .i have the mount figured out but still have questions on how im going to get my cables up in the headliner.does or has anyone removed the grab bar on the A piller or is their a better route?
Old Sep 1, 2004 | 04:08 PM
mlee52554's Avatar
mlee52554
I had an ocassion remove the grab bar and trim panel while looking for a route for power for my radar detector. It was easy to remove...just pop out the inserts that cover the two bolts with a small flat screwdriver. There is a small slot on one side of the inserts for this purpose. I removed the cover on the passenger side since that's the one closest to the fuse panel. After you get a wire routed it's real simple to just push it over the front edge of the healiner...it's molded and floats free...it's not actually attached. It's probably easier to start at the overhead bin area and push you wire forward until it comes out near the windshield...I used a piece of coathanger wire to push my wire through. Then I just pulled it over to the pillar and down. Then I went back and just tucked it in back over the edge of the headliner as I mentioned. Then I just tie-wrapped my wires to the existing ones in the pillar and replaced the cover and grab bar.
3golfjack
36
Mar 24, 2014 10:49 AM
Shadowrider123
20
Apr 12, 2013 08:51 PM
BiltFordTuff
16
Mar 9, 2011 08:43 PM
CaptGuz
May 15, 2007 05:40 PM
LBell101
Aftermarket Products
15
Oct 16, 2004 01:48 PM
