two turbos.
Old Aug 31, 2004 | 06:37 PM
zero^Element's Avatar
zero^Element
Arrow two turbos.
hello i have a 01 PSD i really want to install another turbo for more boost, i would think it would be pretty easy to install im not sure, do i need the same size turbo as i have now or does it not matter? how hard would this be?
Old Aug 31, 2004 | 07:17 PM
CAT_man_963's Avatar
CAT_man_963
Dude - have you looked under your hood? There's barely room for that 1 turbo that's stuffed back in under there!! Actually it's been done - but the one's I've seen had the other turbo kind-of up on top of the motor - assuming needing some kind of custom hood arangment. Also - you better get you're heads fireringed before you even think about twins - your headgaskets will NOT be happy with you!! And you'd need to add a BUNCH of fuel (SERIOUS injectors)to need all that boost and actually do anything with it, and then to drive those big injectors you'd probably need to upgrade the HPOP with one of the new dual setups that are coming out now. Man - I could keep going - the list goes on...................
How hard? NOT at all easy or cheap!! NOT saying it can't be done - but it's a tad bit harder than slapping another stock turbo in-line with yours!!
Old Aug 31, 2004 | 10:48 PM
Kwikkordead's Avatar
Kwikkordead
Here's a good example:
LOL. 70psi 2000 EGT is what he says when pulling the sled.
http://www.4andersn.com/projectpics.html
Old Sep 1, 2004 | 05:07 AM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
How are you planning on running the twin turbo set up?
One turbo for each cylinder bank (parrallel)?
Or two turbos running in series?
