Plastic Intake Manifolds
Old Dec 16, 2004 | 10:39 PM
LxMan1's Avatar
LxMan1
Boy, that looked like a lot of trouble just to use the wrong intake on non-PI heads. Not worth the couple of HP gained for the money. The PI heads have better cams too!!
Old Dec 17, 2004 | 04:21 AM
Ted98's Avatar
Ted98
LxMan1 - it really wasn't that bad. That was stage 1 of my PI headswap. I finally have PI heads on the truck now and only wish I would have done it sooner.
I was wanting to do a coolant modification that I read about about but wasn't able to swap heads at the same time.
Old Dec 17, 2004 | 08:51 PM
BigBlackTBird's Avatar
BigBlackTBird
not that much work for just an intake... a bit of RTV, a dremel tool to sorta kinda port match, hell, you can put PI cams in the npi heads and get a few more ponies. The poor man's step by step plan for horsepower!
Old Dec 18, 2004 | 01:12 AM
termyt00's Avatar
termyt00
Originally Posted by BigBlackTBird
From what I understand, if you can make a bracket to mount the alternator on the engine block or a cylinder head, you reduce the risk of cracking the all composite intakes. Some say that the reason they break under WOT is because the alternator is making one heck of a strain on the intake. So, if you can mount that alternator on a more solid structure, it *should* keep it alive.
My 97 T-Bird cracked in the thermostat tower , and FORD refused to fix it!
personally i think some one goofed on their calculations on how long it would take the plastic to get brittle under the extreme variations of temperature! ...probably a M.I.T. grad...
Old Dec 28, 2004 | 09:22 PM
2002 F350V10's Avatar
2002 F350V10
If you look in the aftermarket, dorman now offers a kit that has a new plastic intake with all parts needed to install at approximately 1/3 of what you would pay at the dealer for it. seems its a big problem with the 1996-2000 engines and they tooled up for it. Bill
ROBBINthaHOOD
Modular V10 (6.8l)
Feb 20, 2024 11:42 PM
SEAL1
Dec 15, 2011 05:18 AM
B Dobz
May 8, 2011 09:09 PM
TXRusty
Modular V8 (4.6L, 5.4L)
Feb 5, 2008 05:35 PM
DrFord
Jun 2, 2002 09:07 AM
