help please
Old Aug 31, 2004 | 02:05 PM
witsend's Avatar
witsend
Unhappy help please
i have a ford bronco 2 with a 2.9 liter engine it starts fine when cold then about 15 min later it will run funny and die it has fuel and spark but won't restart till cooled have tried oxegen sensor ,map senor ,coumputer,ignition module,fuel pressure regulator. thinking maybe the fuel injectors one may be bad would this take out the rest. also need help to find the ohms of restance for the injectors
would really appricate help thank you witsend
Old Aug 31, 2004 | 09:42 PM
LxMan1's Avatar
LxMan1
Sounds like a bad pick-up coil in the distributor to me. It will get hot and quit.
As for the injectors, a good haynes manual will give you proper OHMS on the injectors. I don't know it off of the top of my head.
Old Sep 3, 2004 | 02:34 PM
witsend's Avatar
witsend
Smile thank you
my husband said that sounds right thanks it helps to have friends
thank you again witsend
just think i might have to change my name if this works
Old Sep 4, 2004 | 11:41 AM
LxMan1's Avatar
LxMan1
Good Luck
