i have a ford bronco 2 with a 2.9 liter engine it starts fine when cold then about 15 min later it will run funny and die it has fuel and spark but won't restart till cooled have tried oxegen sensor ,map senor ,coumputer,ignition module,fuel pressure regulator. thinking maybe the fuel injectors one may be bad would this take out the rest. also need help to find the ohms of restance for the injectors
