Running Hot 460
Old Aug 31, 2004 | 11:17 AM
BULLFROG460's Avatar
BULLFROG460
Running Hot 460
I Have An 83 460 That I Put Into A 74 F250 4x4. It Has A 770 Truck Avg Carb, Weiand Stealth Manifold, Heads Off Of A Early 70's Model 429, A Mild Cam, And Headers. It Is Bored .060 Over. I Have An Aluminum Rad, Electric Pusher Fans On The Front Of The Rad, And Also Have A Regular Fan With A Heavy Duty Fan Clutch On The Other Side. I Can Cruise Around Town In It And It Does Fine Temp 180 Degrees. I Get In The Mud And Start Playing It Starts Running About 225 Degrees And Boiling Over. Is There Anything Else That I Can Do To Cool It Off? Any Help Would Be Greatly Appreciated.
Old Sep 2, 2004 | 11:18 AM
73Custom's Avatar
73Custom
Do you have the correct cap and 50/50 coolant mix? It shouldn't really boil over at 225*... should it?
Marty
