Overheating Problem
Old Sep 13, 2004 | 08:44 PM
bigsnag's Avatar
bigsnag
One thing first, make sure your electric fans are pushing in the right direction. They aren't counteracting the real fan, are they??? Also, unless they are really high flow electric fans, they could be hindering even if they are going the right way.
Old Sep 14, 2004 | 11:29 AM
BULLFROG460's Avatar
BULLFROG460
They are pushing the right way. They could be hinderin the flow because they are not high flow fans, they came off an Dodge Intrepid. So I am pretty sure that they are not high flow fans.
Old Sep 15, 2004 | 10:47 AM
ivanribic's Avatar
ivanribic
If you have a shroud on there the stock fan should cool it just fine without any pushers. Without the shroud you're pulling air in from around your engine compartment rather than through your radiator. If you can't fine one you can build your own with sheet metal. I don't remember who it was but someone who posts often in the 73-79 forum has pics in their gallery of a custom built shroud that works great.
Old Sep 15, 2004 | 02:37 PM
BULLFROG460
Thanks for all the info. This info should help alot
Old Sep 15, 2004 | 10:44 PM
Chiefrider007's Avatar
Chiefrider007
Junk yard, old ford car or truck, hack or jig saw, get er done.
