accelertor linkage issue
Old Aug 31, 2004 | 02:13 AM
birdmanlbexinc's Avatar
birdmanlbexinc
i was driving to work yesterday when all of a sudden my accelertor wouldnt work. you would pump and not get any reaction. so i ended up drifting to work with using the choke to get there. took off the carbuertor and it looks like the bracket (that holds the spring that opens the valve on the carbuertor to let in gas) broke in half. like the metal literally tore in half, so now the spring, when you press the gas pedal, doesnt spring at all, thus giving me no gas to the engine...ANYWAYS after explaining that, i need to replace that bracket and assembly, but i have no idea what its called or what to ask for at a parts store. already went to a junkyard near by and all the old trucks didnt have anything left of that sort inside. much help needed. thanks in advance
Old Sep 1, 2004 | 04:20 AM
Cracker289's Avatar
Cracker289
I am not 100% positive what you mean, but from what it sounds like, its time for a new caburetor!
Also, at the junkyard, you don't have to check just Ford trucks, Ford cars should have the same or very similar carb, as will some AMC Jeep vehicles. My 73 jeep Wagoneer came with an autolite 2 barrel carb.
Old Sep 4, 2004 | 09:25 PM
baitmaster's Avatar
baitmaster
simpler is usually better
Dont know what your driving, but when I dropped new 390 into my '72, I scrapped that Dr. Suess looking linkage contraption, and made my own. Simple as a piece of 1/8" steel rod bent at the right places, drilled on the ends and locked in with small washers and cotter pins. Has worked perfectly since. One of these days, I will upgrade carb end with a carb linkage bushing which is easy fit with Holley carb.
Old Sep 4, 2004 | 11:23 PM
bugser's Avatar
bugser
I did kinda the same with my 70 F100. Had a bucket handle laying around. One end was already bent in an "S",so I just weaved it into the pedal link,bent the other end,flattened,drilled a hole,then slid my return spring to hold it together.
Old Sep 4, 2004 | 11:35 PM
68torino's Avatar
68torino
I would also recommend looking in fordbeast_80's gallery, he found a way to eliminate the rod linkage in favor of cable. Looks pretty sano also.
Old Sep 6, 2004 | 04:07 AM
birdmanlbexinc
awesome thanks guys that helps a lot
Old Sep 6, 2004 | 05:35 AM
Torque1st's Avatar
Torque1st
Posting Legend
Make sure you always run a double throttle return spring, one inside the other, for safety. From what you say the throttle return springs did not break but a bracket did. The most common failure point is a broken return spring which can lead to a wide open throttle situation that could be dangerous.
Old Sep 6, 2004 | 07:26 AM
Boyd1971's Avatar
Boyd1971
amen on the springs .I had WOT on a four lane once . I'd go with a cable conversion ,looks good, works great
Old Sep 8, 2004 | 01:44 AM
Mr.Majestyk's Avatar
Mr.Majestyk
ive just replaced that linkage in my truck last week. good luck trying to find it at a salvage yard lol. it took me two weeks to find one and cost 25 bucks lol . ive had suggestions to run a straight cable but wanted to keep an original appearance . good luck to you pard
Old Sep 8, 2004 | 03:16 PM
fordification's Avatar
fordification
Thought I noticed a sketch in freightrain's gallery regarding the linkage.
This is the setup I went with also. Not actually sure if it works with the stock motocraft carb though. Guess it depends if the throttle **** is on the top or bottom(push or pull) of the linkage.
akamacgyver
Oct 7, 2012 11:01 AM
Tiger_and_Apex
Oct 17, 2010 01:54 PM
izza
Feb 22, 2007 08:14 PM
55rodder
Dec 9, 2003 05:49 PM
