rust hole
Old Aug 30, 2004 | 07:43 PM
1972ford_f-100's Avatar
1972ford_f-100
Question rust hole
ok,i was waondering on my 72 ford f100 swb,where the hingers bolt to the body of the truck ,on top there is a rust hole,like i can see the ground,wut do i have to replace?thx all
Old Aug 30, 2004 | 09:05 PM
vazsek's Avatar
vazsek
what on earth is a hinger?
Old Aug 30, 2004 | 11:25 PM
JakeisK98's Avatar
JakeisK98
Must be the same thing as the thing-a-ma-job on my truck.
Old Aug 31, 2004 | 01:04 PM
1972ford_f-100
hinge,sorry bout that
Old Aug 31, 2004 | 05:09 PM
Fritolay's Avatar
Fritolay
which hinge ar you talking about door nige hood nige tailgate hinge???
Old Aug 31, 2004 | 05:25 PM
1972ford_f-100
oh,hood,sorry
Old Aug 31, 2004 | 06:13 PM
vazsek's Avatar
vazsek
i just got a sheet of steel bent and cut the rusty chunk out on both sides, about 8 inches of it after i marked new "hinger holes" lol, and welded it in. you can tell i did it by looking at it but it is heavier steel.
Old Aug 31, 2004 | 07:38 PM
1972ford_f-100
how many layers are there
Old Sep 1, 2004 | 05:35 PM
Fritolay's Avatar
Fritolay
if you are good at welding or have the resources just cut out the bad spot and get a piece of plat and weld it back in or you could cut a slightly larger piece and bolt or rivet it to the existing inner fender or just replace the inner fender.
Old Sep 2, 2004 | 10:04 AM
michaelbrainardatwor's Avatar
Another hole/bondo question. I am in the process of filling the holes in my 69 body that were intended to hold the trim clips....range in size from 1/8" to maybe 1/4 or 5/16?...anyway must these be welded or can I use Duraglass? What is the best way? I don't want to mess with trying to weld them all shut and end up distorting the door and body panels....
Old Sep 2, 2004 | 05:09 PM
1972ford_f-100
dude,i dunno,but how many layers do i have to replace????
Old Sep 3, 2004 | 12:29 AM
Fritolay's Avatar
Fritolay
layers?? there shoudl only be one piece of metal that the hinge is bolted too but the best addvice is to cut out all the rust spots and replace them with new steel if you havent looked under the battery tray this may be a good time because you may find the same thing (large rust hole) if so my $.02 would be too replace the inner fender.
as for the other guy my dad welded all the holes shut on his truck and never warped a panel you just have to be carefull about how you do it use low heat try to use a piece of heavier material behind the hole (a hammer usually works good ) to keep form burning through and then skip around while welding dont work in a straight line weld one hole in the frint then go to the bed and weld one then the back then go to the other side and go until all the holes are filled.
