swapping trannys
Old Aug 30, 2004 | 12:47 PM
BroncoRoadKill's Avatar
BroncoRoadKill
swapping trannys
I was wondering if anybody here new what I would have too go through too swap in a zf-5spd. into my 83 f-150 it has 302 now w/ an aod, 2wd.
I do plan on swapping ini a 351w later, but that should be no problems, I know I will have too find the pedal brakets, master cylinder, salve, and hydrolic lines.
Will I have too get my driveshaft extended?
Thanks,
Clint
Old Aug 31, 2004 | 12:40 AM
BroncoRoadKill
someyones gotta know.
Old Aug 31, 2004 | 12:52 AM
mustange70's Avatar
mustange70
You also need a flywheel, and new clutch, if you need a longer driveshaft find one of a truck that is already longer and get it shortened to lenght cause this will save you some money.
Old Aug 31, 2004 | 01:42 PM
BroncoRoadKill
Oh yea, forgot the flywheel, Also, will my stock crossmember work or can I just do minor mods too make it work?
Old Sep 1, 2004 | 12:06 AM
mustange70's Avatar
mustange70
It should work, you might have to move it back by drilling some new holes, no biggie but can be a pain in the butt (use and air drill, lighter and just as powerfull as a 1/2 electric)
Old Sep 1, 2004 | 10:10 AM
stangboy_82's Avatar
stangboy_82
problem with the air drill just so you know when you're drilling through steel you need to go at about 50% speed that you would go for aluminum(full out) so practice for awhile cause that's hard to do on most air drills or if you don't want to slow it down by trigger control then just lower the air pressure into the drill. have fun
Old Sep 4, 2004 | 12:07 AM
BroncoRoadKill
Oh yea, I have had fun drilling into steal with air drills, nothin but fun.
Thanks for the info.
Old Sep 4, 2004 | 10:16 PM
Samsonitesamsonite's Avatar
Samsonitesamsonite
i plan on doing the same thing to my truck... the only changes i will have to make is to the mounts and shortening the drive shaft.
Justinblocker82
Engine Swaps
Sep 13, 2013 08:16 AM
frank_kay1
May 8, 2013 04:06 PM
CDF302v8
22
Jan 5, 2011 11:22 AM
crowes99
Aug 24, 2010 10:13 PM
ke5adb
Engine Swaps
Feb 9, 2009 04:35 PM
