Stacking the edge with the predator
Old Aug 30, 2004 | 11:49 AM
03250stroke's Avatar
03250stroke
I have tried this combo and it does not see to have any effect on my truck, I wanted to ask for those that ahve done this did you go back to stock then and for how long? Then install the predator and wait how long before installing the edge? Any of you who have done this did you see a significant gain over the edge alone? Any dyno numbers or track ET. ANy help would be great.
Old Aug 30, 2004 | 01:54 PM
va_redneck's Avatar
va_redneck
I too would be interested. I run the Edge and have been very happy with it. I would like to alter my shift points and have considered stacking but fear that it may screw things up.
can you jsut adjsut the tranny with the predator?
Old Aug 30, 2004 | 02:04 PM
jdadamsjr's Avatar
jdadamsjr
when you say adjust the tranny, you mean ?????
and stacking is something I won't ever do... but some have depper pockets than mine
Old Aug 30, 2004 | 02:13 PM
va_redneck's Avatar
va_redneck
I was shooting to say tranny for transmission but after checking what else TRANNY stood for I may want to see a shrink to see if I have some suppressed event from my childhood.
I wanted to see if I could set the shift to be firmer without adjsuting the fuel and timing. i.e. let the edge tune the engine and just use a tuner to mode the transmission.
Old Aug 30, 2004 | 02:57 PM
jdadamsjr's Avatar
jdadamsjr
The predator does have a stock mode...
ah heck... I'm not the one to talk to about this...
let me tap psd on the shoulder he's done some stackin...
course he is on his second engine now so maybe he won't this time
Old Aug 30, 2004 | 03:02 PM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
You can stack safely, if you use your common sense. Loading the predator shifting on top of the edge program (no predator engine tuning, just shift and speed de-limiter) should work great. I had both my Edge and SCMT in for a while on the good engine; the SCMT overrides the de-fueled shifts and it works great. The only problem I ran into was the fact that I could'nt load just the transmission program, and the timing was too advanced with both running at the same time. I would not recommend running both engine tunes at the same time, but one for engine and one for transmission should do great.
Old Aug 30, 2004 | 03:08 PM
va_redneck's Avatar
va_redneck
If you had your choice would you keep the Edge or pull the edge out and go with 100% SCMT or Predator?
I like the Edge but I don't know if a tuner would be better all the way around.
Old Aug 30, 2004 | 07:54 PM
03250stroke
of the three
The edge hands down makes the best power. How do I load just the transmission file?
Old Aug 30, 2004 | 08:14 PM
SpartanDieselTech
Former Vendor
SAME PROBLEM ive been having.... but the longer I drive it the Edge shifting just keeps getting better, even at 750 plus miles..
But yes, I agree about it making more power. It does
josh04hdf250
Aug 3, 2009 10:03 PM
AZ4x4f150
General Automotive Discussion
22
Feb 8, 2007 02:58 AM
Excursionator
Oct 21, 2006 01:20 PM
XxfirmanxX
Dec 13, 2005 09:11 PM
1wheel
Computer Chips & Tuners
Jan 15, 2005 09:42 AM
