Lock Cylinder
Old Aug 29, 2004 | 09:04 PM
DustyDogBM03's Avatar
DustyDogBM03
Lock Cylinder
How do I remove the lock cylinder . Manuals sey to put a punch up the hole below the cylinder. I have a 1991 Explorer and I cannot find any hole
The key is in it in the "on' possition and ...wait do i hear my truck ?
Help
Dusty
Old Aug 30, 2004 | 02:22 PM
DustyDogBM03
Key Cylinder Hole
Thanx for your help....Found it! The picture in the haynes book is all wrong.If you have a replacement cylinder, you can eye-ball where the lok pin is hiding on the column.
If you notice where it should be follow, in the molded metal and at about a 45 deegree slant,down towards the floor and foward,that shaft.
The place to put the small punch is under and behind the covering above the tilt arm. I didn't have a short screw driver ,so i used a nail. A little wiggle-wiggle and it was free! Forgot to replace the "chime" wire before I snapped in the new cylinder ....oh well
Dusty
RollinK
Jan 5, 2017 03:56 PM
earlybirds
Dec 3, 2016 10:10 PM
TheBigF
1997 - 2003 F150
May 3, 2010 02:15 AM
jf351
1978 - 1996 Big Bronco
Jun 14, 2009 05:39 PM
