Can any one tell me the following specs:
For an 85' F150 4x4 reg cab long bed.
Rate
Load at curb height
I.D. &O.D.
Bar diameter and bar length
number of turns
Free height
thanks
so i can put 2wd coils up front on a 4wd?
that might be easier than having my dad custom make my springs
then i would have 3/4ton springs on all 4 corners.
i'd have to go and get an F250 Badge then
not quite, if you are still runnin the 5 lug semi floater axles. but i pulled some coils off an 84 3/4 ton and they were a direct no mod/rigging needed bolt on.
good luck on your project.
yea mine are worn. on the drivers side it kinda sags and you can see that the tire doesn't look right all ****-eyed whee the bottom is farther out from the top and it is lower than the right side.
Reason: spelling
what about F350 2wd Springs from and 87?
the reason i ask is because there is one at the junk yard and i can get the springs for cheap
would the rear springs fit on my truck?
the 87 is a duelly
