antilock? brake problem 97 E-150
Old Aug 29, 2004 | 06:54 PM
hrs999's Avatar
hrs999
Question antilock? brake problem 97 E-150
1997 E-150 with a 4.6 liter & 4 wheel anti-lock brakes. Occasionally under light braking pressure at low speeds (<10 mph) when I step on the brakes the pedal doesn't go down. I can hear a noise (something like the antilocks kicking in) and if I release the pedal and press the brake again everything is normal.
Anyone with any ideas
Old Sep 1, 2004 | 05:56 AM
trike1946's Avatar
trike1946
You should be able to feel the antilocks pulsate if they are working. How is the master cylinder and the power booster?
Old Sep 1, 2004 | 07:23 AM
hrs999's Avatar
hrs999
last winter the anti-locks worked fine, don't recall them being activated since then, the master cylinder and power booster are original, I have not really done any inspection on them yet. I'll give the antilocks a test to see what happens.
the_real_zekenator
Oct 30, 2013 12:37 PM
Hotairjunkie
Jun 26, 2013 08:40 AM
ret72
29
Aug 30, 2010 09:14 PM
Rob88
16
Jul 11, 2001 12:30 AM
Alex Stephan
Feb 22, 2000 07:14 PM
