decoder help, "C9" (axle), "K" (trans)
Old Aug 29, 2004 | 12:33 PM
z9jwgarza's Avatar
z9jwgarza
1986 f250, 4x4, 6.9L dsl.
Axle: "C9" (good or bad)?
Trans: "K" (good or bad)?
I do lots of highway driving & gas milage is the most important.
The things that I tow are relatively light trailers & only on occations.
any info on this is highly appricieted. thx z9jwgarza
Old Aug 29, 2004 | 12:40 PM
SoCalDesertRider's Avatar
SoCalDesertRider
C9 is a 3.55 limited slip in a Ford 10.25" full-float, 6250 lb GAWR. The 3.55 ratio should give you descent fuel mileage on the highway.
I dont know what trans K is. If its a 3-speed auto trans (no OD gear), it will be a C6. I think that is the only auto trans offered in that truck in that year with that engine. If it's a manual 4-speed with granny-low 1st gear, it's either a Spicer T-18, T-19, or NewProcess NP435. They are all good transmissions. Your GVWR should be about 8200-8800 lbs and your GCWR should be about 13,500 lbs, meaning you can tow a trailer weighing up to about 8000 lbs.
Your truck will be fine for what you are intending to do with it.
Old Aug 29, 2004 | 12:54 PM
z9jwgarza's Avatar
z9jwgarza
thanks socaldesertrider
yes it is an automatic, now the 10.25" is that the ring gear diameter?
Old Aug 29, 2004 | 06:22 PM
SoCalDesertRider
Yep that's the ring gear diameter.
Old Aug 30, 2004 | 12:57 AM
SoCalDesertRider
One correction on something I posted eariler. The T-18 is a Borg Warner trans, not a Spicer. Sorry for the mistake, I wasn't thinking clearly....
Mtnhermit
Apr 30, 2016 12:57 AM
Arizona97
Feb 4, 2016 07:09 AM
ag-ford-4x4
Aug 14, 2012 03:12 PM
Piolet
Jun 25, 2012 08:54 PM
