Aerostar Ford Aerostar
95 Aerostar- No interior heat, engine overheating
Old Nov 13, 2002 | 03:47 PM
Lamicus's Avatar
Lamicus
I've got a 95 Aerostar, 3.0 liter, and now that it's cold outside, the heat stopped working and as of yesterday, she's overheating something fierce. Is this a thermostat problem, or something worse?
No visible leaks under the vehicle (kinda hard to miss antifreeze on snow)...just a crapload of steam coming from the grille.
Any ideas?
Thanks.
Old Nov 13, 2002 | 04:02 PM
aerocolorado's Avatar
aerocolorado
Thermostat is a likely culprit if you have already ruled out loose/broken fan belt, low coolant level or upper/lower hose problems. If a thermostat change out does not correct the problem then more serious issues would be water pump or radiator related concerns. Thermostats are a frequent problem with the 3.0 and 4.0 engines, so that would be a logical and inexpensive starting point. They come in four or five different temperature ranges, so ask at the desk for help if unsure of the correct one for your application.
Old Nov 13, 2002 | 06:44 PM
Avanti's Avatar
Avanti
I would pull the thermostat and put it in a cup of boiling water & see if it opens. If it does you know you found the problem. If it does open I would replace it & than go pull the water pump. I have seen it were the pump blades were broken or loose on the shaft causing no heat & over heating.:-staun
Old Nov 15, 2002 | 09:06 AM
WWildbh's Avatar
WWildbh
Car Guy
Aerostar
Feb 8, 2016 01:48 PM
hogheaven
Jun 25, 2015 02:29 PM
2aerostars
Aerostar
May 3, 2015 08:21 AM
gwm
Aerostar
24
Jul 12, 2008 02:55 AM
dougas
Aerostar
May 22, 2002 10:14 PM
