Bronco II Ford Bronco II
radiator
Old Aug 28, 2004 | 08:07 PM
'87BroncoII's Avatar
'87BroncoII
radiator
i just cracked my radiator and i was wondering if there was a larger radiator made for the bronco II or better yet one that would fit into an 87 bronco II off of a donor vechile would a explorer radiator work??? any others that would work better
Old Aug 29, 2004 | 02:19 AM
Monty06's Avatar
Monty06
Wink bigger radiator
you can use one from a 91-94 explorer jus keep your lower hose from the 2.9 and get the top one from the 4.0 you might need to shave off a little of your fan shroud but's direct fit. easy should take 20-40 minutes
Old Aug 29, 2004 | 10:09 AM
'87BroncoII
hey thanks thats exactly what i needed to know
Old Aug 29, 2004 | 03:39 PM
Monty06's Avatar
Monty06
on bigger rad
no problem man i do this to alot of b2's here in miami alot of people don't thave the mechanical nohow so i do it for about 40 bucks . if you any more help let me know
Old Sep 4, 2004 | 06:35 PM
'87BroncoII
nice!!!!
the radiatior swap worked wonderfully my engine dosent go over 190 degrees now and it used to run at like 200 however any one who is doing this swap make shure you have the used radiator boiled out if you buy it from a junk yard also you dont need the upper radiatior hose it is a direct replacement all the hoses match up perfectly *well at least in my case they did*
Old Sep 4, 2004 | 11:06 PM
RomerB2's Avatar
RomerB2
what do u mean by boiled out?
Old Sep 14, 2004 | 11:20 PM
dino360's Avatar
dino360
Angry
I replaced mine and it was bad. be sure to get it checked if it is used.
pfcperry17
Bronco II
Aug 14, 2010 12:24 PM
svooom
70
Jun 15, 2007 10:48 PM
kendell
Oct 14, 2003 09:17 AM
JavaMoose
Bronco II
Sep 12, 2001 01:17 PM
wittey
Bronco II
Jun 11, 2001 03:45 PM
