Bronco II Ford Bronco II
oil leak
Old Aug 27, 2004 | 03:50 PM
'87BroncoII's Avatar
'87BroncoII
oil leak
i have this oil leak it is just a drip but it drips out about a quart every week and a half it seems to be coming from my oil filter or maybe the oil filter tap where it connects to the block
Old Aug 28, 2004 | 10:52 AM
KawiG5's Avatar
KawiG5
Just for the heck of it, do an oil and filter change. When you remove the filter, check to see if the filter tap is loose. I have had to tighten the tap on my '89 BII due to being loose. Sometimes they loosen from removing the filter. After changing the filter and checking the tap, run it for a few days to see if it has stopped.
Also check to make sure that any old filter gaskets aren't left behind on the base. I also have had that happen. The rubber gasket would pop out of the filter when removing it and would stay in place on the base.
Old Aug 28, 2004 | 07:56 PM
'87BroncoII
i all ready did that and im shure there wasnt a old gasket on it when i put the last filter on because i did a rebuild on the engine and i remember cleaning all the gunk off of the tap and i cant get a wrench to the tap because the exhaust manifold is less than an 1/4 of an inch away from the bolt any suggestions???
