Brake controllers
Old Aug 27, 2004 | 11:33 AM
loudfords's Avatar
loudfords
Question Brake controllers
Looking at getting a trailer brake controller for my truck. Are they all compatible, or will certain controllers only work with certain trailers?
Old Aug 27, 2004 | 12:04 PM
Hank85713's Avatar
Hank85713
You want to buy the best you can afford for towing. Not saying the high $$ are any better than the discount ones. Many have recommend the predator I think it is runs around $100-150. I was going to get one but had two already and decided just to reinstall into the new truck and did. One was bad, the other works good.
So yes you can make your choice and they all will work on the trailers. Some I have read indicate 2 or more axles so I would get one that has multi axle capability.
Old Aug 27, 2004 | 04:38 PM
RedTaurus94's Avatar
RedTaurus94
Brake Smart or Tekonsha Prodigy
Old Aug 29, 2004 | 01:49 PM
huntercgr's Avatar
huntercgr
If you have electric brakes the Prodigy is your best value. They can be had for $125 including the wiring harness and shipping. If you don't need the harness, as I doubt you would, take off $12.
Old Aug 29, 2004 | 08:38 PM
rclarke's Avatar
rclarke
The Prodigy brake controller is $99.95 at rvwholesalers.com
Old Aug 29, 2004 | 09:37 PM
RedTaurus94
Yeah, but shipping is $9 and the wiring harness is another $11, I think it is.........
Old Aug 29, 2004 | 10:35 PM
huntercgr's Avatar
huntercgr
Actually, the total came to 120.24. Sorry, my bad. hehe
Old Aug 30, 2004 | 11:41 AM
elliott's Avatar
elliott
I've also heard that Jordan makes a Very good one, some in camping magazines say the best.
Old Aug 30, 2004 | 11:55 AM
wlihntr's Avatar
wlihntr
i will give a thumbs up for the tekonsha prodigy as well. it is very easy to set up and use, and it works very well
Old Aug 30, 2004 | 03:38 PM
loudfords's Avatar
loudfords
Thanks for the input guys. Referring back to my original question, will the Prodigy be able to activate the brakes on any trailer? Are the plug sockets for most trailers the same?
Old Aug 30, 2004 | 05:13 PM
Bordaine's Avatar
Bordaine
If the trailer has electric brakes, the electric brake controller will work. If it has some other type of brakes the controllers will not work. Most trailers now have electric brakes. Except maybe boat trailers.
Most trailers are usually wired with a flat four plug (no brakes), or a 7 way plug with flat spades.
Old Sep 3, 2004 | 04:54 AM
keith w's Avatar
keith w
Yep, that sounds like the price I paid. It boiled down to a Brakesmart for $350 or the Prodigy for $120. I tow an open utility trailer so I figured it would be fine. The harness they sell makes it a Plug 'n Play deal. Simple install, I believe a monkey could do it.
Old Sep 3, 2004 | 11:36 PM
NewJim's Avatar
NewJim
thanks Kieth w, you just answered the question I was going to ask.. I've already shelled out loads to Trucksmart and could save $50. For my 04 F250, do I need to get a harness? I found a 5 wire harness with "Electrical trailer tow installation instructions" in the glovebox.
Old Sep 5, 2004 | 07:49 PM
Gene W's Avatar
Gene W
New Jim,
I will also recomend the Tekonsha Prodigy. I just got back from a 1000 mile tow and mine worked flawlessly.
My van came with the same pig tail that you found in your gloove compartment and the Prodigy will come with a pig tail that you can splice to it if you like....BUT... read the instruction sheet if you choose to go this route because you don't simply match the colors from one pig tail to the other. Also, if you need extra length you will need a couple of different wire gauges.
The optional three foot custom wiring available for your particular vehichle is a bargan at 10 to 12 bucks and makes it plug and play.
Gene
Old Sep 9, 2004 | 01:49 PM
McHarward's Avatar
McHarward
Lightbulb
The Prodigy Is Definity The Way Too Go. I Work In A Rv Parts Department And Have Personaly Used Many Differant Brake Controls. Many People Like A Pendulum Controler, Hayes Lemmerz For Example, Because They Claim To Be More Sensitive ( Not As Much Jerking ) As An Electronic Control. Electronic Brake Controls Have Become Very Popular In The Last Few Years Because They Are Very Predictable. I Can Set It To Hit Just How I Like It No Spending The First Five Miles Of The Tow Messing With It. I Tow Several Trailers A Week And Have Been Completly Satisfyed With The Prodigy. Prodigy, The Best Brake Control.
