Offroad & 4x4
Pushbutton vs stick
Old Aug 26, 2004 | 09:09 PM
dan1101's Avatar
dan1101
Pushbutton vs stick
I'm looking at a 96 F-150 with a V8, automatic transmission, and pushbutton 4wd.
I know there's a lot more to go wrong with pushbutton 4wd, but I'm pretty easy on my vehicles. Assuming the thing keeps working, is there any difference operationally between pushbutton and stick 4wd?
Old Aug 26, 2004 | 09:20 PM
JeremyH's Avatar
JeremyH
Electrical wiring versus manual lever. Not much more.
Old Aug 26, 2004 | 09:47 PM
FordPerf300's Avatar
FordPerf300
Peace of mind that you know it's actually locked in 4wd when you push the lever.
Old Aug 26, 2004 | 10:13 PM
fishmanndotcom's Avatar
fishmanndotcom
the 4wd motors are notorious for failing at the worst possible moments
other than that......... NOTHING
-cutts-
Old Aug 27, 2004 | 03:44 PM
hoxiii's Avatar
hoxiii
::Supposedly:: there is some relatively simple way to engage the t-case if the shift motor fails. I've had 2 salesmen and 3 techs tell me this, but none of them have been able to demonstrate exactly how.
The best thing for the shift motor is to use it and use it OFTEN (as in monthly at a minimum) to make sure it doen't seize up. You don't have to use the 4wd, just engage and disengage it a couple of times so corrosion doesn't get a chance to build up.
I just like being able to use a screwdriver to shift if my linkages blows instead of having to pull a shift motor and then use a screw driver to shift.
Justin
