Air filter
Old Aug 26, 2004 | 05:32 PM
TX_F4OxR4D's Avatar
TX_F4OxR4D
Air filter
Alright...no one laugh. What is the secret to removing the air filter, besides undoing the clips? I don't want to force anything. Thanks.
Old Aug 26, 2004 | 05:54 PM
ToddSr's Avatar
ToddSr
You have to be a midget contortionist.
Old Aug 26, 2004 | 05:58 PM
Frobozz's Avatar
Frobozz
You have to loosen things up from both ends, and the filter not only "plugs in" to two bracket sockets underneath, it also slides into mesh with the end caps on the bottom of each opening. All while being under pressure from the end gaskets. Once it does all finally come apart, it will drop out in your lap and you'll wonder what the problem was. I think getting it in is the trickier part. I think if I had lubed the rubber seals with silicone grease it would have gone a lot easier.
Remember that it's that rubber part, inset from the edge quite a bit, that does the sealing. So even though there will be a visible gap at the back end between the filter and the end cap/hose, it doesn't matter because the rubber seal is still solidly closing the airflow. Well, you should look in there to make sure it looks like it's place, anyway.
Duncan
Old Aug 26, 2004 | 06:24 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Duncan
and twelve more things, when you get both ends loose, hold you mouth tight and to the left, all the while balancing on the chrome slippery bumper, making sure you do not slam you right elbow into the inner fender well when your left foot slips off the shinny bumper, falling back you lean forward to catch yourself , resulting in the smacking of your head right above the headlight, causing you to lose control of the 52lbs of air filter, which now... is falling at a slower rate then you…..as soon as you hit the ground roll to the right this will keep you from being impacted by the largest and heaviest filter Ford has built.
Take two aspirin then post here... how you are.
Old Aug 26, 2004 | 06:28 PM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
Not to mention don't loose the little retainer cam ringy things on top that anchor it in...one of them is still in the engine compartment somewhere from the last time I had it apart... Maybe it will show up when I change motors again
Old Aug 26, 2004 | 06:30 PM
IB Tim's Avatar
IB Tim
Now we know what REALLY happened, it ingested it…and you thought it was because of HP
Old Aug 26, 2004 | 06:33 PM
SpartanDieselTech
Former Vendor
This was just a few days ago, lol.
Old Aug 26, 2004 | 07:37 PM
TX_F4OxR4D's Avatar
TX_F4OxR4D
Whew......I think I'd rather dig a ditch barefoot than do that again. Thanks for your help, but I don't think two asprin was enough.
Old Aug 26, 2004 | 11:11 PM
SBV45's Avatar
SBV45
It is a "two knuckle" job.
Old Aug 27, 2004 | 08:12 AM
Hjudge49's Avatar
Hjudge49
There is a service procedure instruction posted on a thread somewhere on FTE that gives step by step instructions for this. But I've found it's easier to remove the entire arrembly in one piece, intall the new filter and reinstall the entire assembly in one piece.
