Lobe Center Angle, Lobe separation Angle, Lobe Displacement Angle all equal the same thing. It is the distance in degrees from the exhaust peak lift to the intake peak lift.
Overlap has zero effect on cranking pressure. The intake opening and closing events of the cam have everything to do with it. A wider LCA cam (if installed straight up)moves the intake event further into the compression stroke and therefore decreases cylinder pressure more than a narrow LCA cam installed straight up.
If your cam has a 110LCA and a 106 IntCL then it was installed 4 degrees advances which seems to be the going trend among many manufacturers.
Russ, as for stall converters I don't consider weight. A perfect stall converter stalls out right before the torque peak. However, in a street driven vehicle where a stall that perfectly matches your cam is far from feasible I would rather have the higher stall in the heavier vehicle to help get it going.
There are much hotter cams in the hydraulic fashion than the 801. You can get hydraulics up to 270 degrees @.050 and over .650 lift. Take a look at www.lazercams.com. That is where my next cam is going to come from.
Crane has hotter hydraulic cams than the 801. Look at the 344621. 296/300 adv duration, .554" / .563" lift.
With this cam you would gain next to nothing on the top end and lose a lot of low end torque compared to the 941 or the 801.
What's the obsession with big cams? Do you like driving around at 3500rpm, having no low end torque to speak of, and getting 5mpg? Or are you planning a strip only race truck?
Yep, tried the 344621 on DD, lost quite a bit of low-end and about 3hp/tq off the top. What's my obsession with big cams? More power! I have gobs of low-end torque. Strictly street/strip. Trying to catch to my brother and shave a second off. Just relized the next step will be a big one.
Rat that is what i was talking about as far as lobe over lap my cam intake opens 40 BTDC and close 72 ABDC and exhaust opens 80 BBDC and close 32 ATDC so both the valves are open 72 degrees at the same time please correct me if I am wrong but I believe this is how I understand this??
Yes that is right but overlap doesn't drop cylinder pressure like you said. Technically if you heavily advance a big cam with a huge overlap the cylinder pressure can be the same as a small cam but it wouldn't run right.
If you have two cams with identical lobes but different LCAs the cam with the wider LCA (less overlap) will have less cranking pressure if both cams were installed straight up.
Rat thanks on the info!! Cams are so hard to pick and even more technical to understand I usually try to get any and all information when were talking about cams and their specs.
